Question about Sharp R-1481B Microwave Oven
Sharp r-1481 950 Watt microwave oven problen
Everything work except does not cook
  • 2 more comments
  • lewisra Nov 12, 2008
    Was boiling water on stove top and exhaust was not on. Started microwave and heard a loud "pop". Everything works but doesn't cook. It is a little louder than usual.
  • Crew Chief Feb 02, 2009
    Was cooking noodles on right rear stove top and exhaust was not on. Started microwave to heat food and heard two very loud "pops". Everything including the inside light and exhaust fan works but doesn't cook. It is a little louder when trying to heat (which don't work) than usual. It had made popping noises a year or so ago but kept on working so I thought it was ok until today.
  • sammim1369 May 16, 2009
    I was also cooking noodles on the right rear burner and heard a pop, then no heat. Everything else works and the microwave is obviously louder.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises? Is it louder or quieter than usual?
    These answers will help me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
Found the answer by calling a Sharp technician and they said it was the magnetron tube, which is not worth fixing :( Thought I'd pass this on to anyone that has yet to find out.
Posted on May 16, 2009
SHARP MICROWAVE MODEL R1406 POPPED, NOW NO HEAT BUT EVERY THING ELSE IS FINE . CALLED IN TECH TO LOOK AT IT $65.00 30 SEC LATTER TOLD ME IT NEEDS A MAGNETRON $100.00,CAPACITOR $50.00, POWER DIODE $30.00, $120.00 INSTALLATION=$300.00
SAVE YOUR MONEY FOR A NEW UNIT. ONLY PROBLEM IS INSTALL COST IS AROUND $175.00 . ALMOST AS MUCH AS MICROWAVE !!!!!
GOOD LUCK; RONNIE H
Posted on Dec 10, 2009
Wattage for mc 1000b microwave
By the name I would think that it is a 1000 watt Microwave. Wattage as in cooking power is what you wanted? Running wattage, a 15 amp circuit will work fine. A 120 volt, 1000 watt microwave will use 13.4 amps (1,600 watts) of electricity in a full power cooking cycle. I think that covers everything! ..:)
May 16, 2014 | Magic Microwave Ovens
Auto Cook not working
If autocook is not working and everything else it, there is an issue with the sensor in the oven that detects the steam, The emission of steam is what triggers that unit to shut off. If it wont cook on any settings then the issue is with the microwave generator not putting out enough power. This could be from a lot of things.
Dec 16, 2013 | Sharp R959SLMA 900 Watts Convection /...
Everything on microwave works except it doesn't heat or cook. what is the problem?
IT'S THE MAGNITRON - CHEAPER TO BUY NEW THAN REPLACE - SORRY.
Jan 09, 2013 | Microwave Ovens
Microwave not heating
There are three common problems, bad magnetron, cracked high voltage diode, and a shorted capacitor, getting it serviced will not be cheap comes down to a personal decision.
Mar 31, 2012 | Sharp Microwave Ovens
I have a 2004 Sharp R-1214 1100 Watt Microwave and the card like removable 3 x 4 inch plate broke (almost like cardboard) and it covered the vented opening. I don't have a users manual so I don't know the...
That's the waveguide cover you're talking about. It covers the opening in the side of the cooking cavity where the microwaves enter. The oven will work without it, but if you don't have the cover in place, food particles can get into the waveguide and cause problems. You can buy a replacement here.
Feb 07, 2011 | Sharp R-1210 Microwave Oven
Sharp R - 630 D 1100 watt microwave, No heat, everything else works , no bussing sound, already changed the high voltage rectifier, ?????
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 07, 2010 | Sharp R-630D Microwave Oven
DCS - CMO24SS - 900 Watt - Microwave not Heating
If all appears to be running as its working but just no heat. Could be issue with magnetron. You could also have loose connections to magnetron or somewhere in high voltaged as well.
Nov 24, 2009 | DCS CMO-24-SS Convection/Microwave Oven
Sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
May 29, 2009 | Sharp R-1871 Convection Microwave Oven
Microwave runs, but does not cook anything. says sensor error
The magnetron, which is the device which creates the microwaves might have got damaged. If so, it should be replaced. Magnetron is the costliest part in a Microwave oven, check the price before before servicing it.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 01, 2009 | Frigidaire FMT148GP Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Sharp R-1481B Microwave Oven Logo
640 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
