Question about Samsung HLR6768W 67" Rear Projection HDTV
Samsung 6768W DLP 2 yrs old Replaced lamp and now color is off Faces look like paint by number
Samsung HLR6768W Lamp was replaced but now we can't get the colors synched up. Some colors are bright, some are dull and it depends on if we are watching HD, a DVD or a non HD channel. Faces look like paint by number, no blending of the colors. Any ideas?
Possible solution:
  1. You may need to adjust the index delay after the replacement. You will be able to tell because you may see strange color banding in any scenes that have colors close, but not quite the same, in tone. This is usually most obvious in face skin tones (i.e. “clay faces”). If you need to adjust index delay, turn off the set, wait for the lamp to cool down, then hit mute-1-8-2-power in succession. The set should turn on with the service menu popping up eventually on the left. I don’t remember which submenu “index delay” is under, but find it and usually it will need to be lowered. I believe mine started out in the mid-50’s and had to be lowered to 47. These numbers are different for each Samsung model, so just adjust until the picture is pleasing to your eye. By the way, the supposed “correct” way to do this is to make the reddish part of the test color bar appear the “most saturated”, if you have a color calibration device.
Posted on Apr 30, 2010
Dlp tv color goes fuzzy and green
Its probably unrelated to lamp, take the lamp out, try it again and look into the lens, if its still very green the projectors electronics are failing. The projector generates pictures as 3 streams of info Red Green and Blue. It looks like the projectors red and blue electronics are failing, but the green is working.
Dec 14, 2013 | Samsung Televison & Video
Samsung HLR5064W DLP TV load vibrating noise like a fan blade hitting something, lamp light is one, Tv will light up but discolored
Sounds like a bad color wheel----remove lamp---the wheel faces it--look for missing pieces or the wheel shattered---these are known for the wheel making a loud high pitched sound or even a grinding sound if the wheel shatters.
if wheel bad You Tube has video instructions for replacing it---seen several people able to do this themselves in about a hour. Google the model number to ("color wheel") to locate a replacement on the internet.10_24_2012_3_58_01_pm.jpg
Oct 24, 2012 | Samsung HLR5064W DLP Projection TV
All the lights are blinking
If a DLP suspect first the lamp, then the color wheel, which are the two most common failure parts in this set.
Color wheel faces lamp--look to see lamp not shattered inside and color wheel not missing parts of the plastic wheel at the same time as lamp is removed--it faces the lamp.
Jun 01, 2012 | Samsung 50" Slim-Depth DLP HDTV
Have a dlp samsung HLT6176S no picture already replaced the bulb still no picture what gives
Remove the lamp and look at the color wheel that faces it.
If wheel is shattered or missing pieces set will know it is not moving or moving too slow and shut set and lamp off.
Not all color wheels when fail make a sound
May 06, 2012 | Samsung DLP HL-P5663W 56" TV
Help please. Samsung DLP no picture just audio
Hi,Is your tv close to 6000-8000 hrs 2-4 yrs.If its it might be time to replace the lamp.Your part # is XL2200 Make sure you get the Philips lamp.There's other components that tend to go bad like the ballast which is the board that powers the lamp.When that is bad it will make continuous clicking noises or attempts to light up the lamp.But if you dont hear any of that then most likely its just the lamp that needs to be replaced.Have a blessed one!
Mar 01, 2010 | Samsung HL-R5078W 50" HDTV
TV screen goes black, 43 lites appear and TV shuts off after 2 to 3 hrs of operation. It will restart OK however. 56" set is 4 yrs old, orig lamp in TV
If you have never replaced the lamp it is most likely to be the problem.Most lamps last 2-3 years under normal use.
Nov 22, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HLR6768W 67" Rear Projection HDTV Logo
405 people viewed this question
Jerry Greenberg
Jerry Greenberg
