Question about Breadman TR2200C Ultimate Bread Maker
Breadman Electronics My Breadman TR2200C will not work. The display will show the blinking time but none of the functions will work. I tried a reset. This did not work. I want to replace the micro processor battery. Can you tell me where to get the battery. It is s 5 volt button size battery. Can you buy the battery at a store like Circuit City or Best Buy. How about Batteries Plus? Thanks WC
  • gadgetgeek2 Jan 12, 2009
    Did you have any luck with this? I tested the battery in my Breadman Ultimate and it's only reading a little over 3 volts. But it's not any standard battery that I've ever seen. It looks like two button cells together, and there are no code numbers or markings of any kind. Button cells are usually either 3 volts or 1.5 volts, so I have no idea how you could combine them to get 5.5 volts, like it says on the blue band around the batteries. Radio Shack had nothing like it. Any ideas where to get one?
    Thank you,
    Steve
You can buy specialty batteries like this one at Radio Shack or Home Depot. Or you can order them online - do a Google search for the code number stamped on the battery and you will find online retailers who sell it. Another good source of hard-to-find batteries is eBay. Go to www.ebay.com and search for the battery code number.
Posted on Oct 23, 2008
My Breadman Ultimate TR2200C stopped kneading. I checked the Problem & Solution board and saw the listing regarding "Breadman...stopped working". I verified the belt and teeth are on...
Check to see if the power cord gets power to the machine. Often, that is a problem for a number of small kitchen or household electrical appliances. Replace it if not functioning, OR, if you can find where the break in ythe line is ( if that's the problem), you can cut off part of the cord at the break and re-attach the cord to the machine. Hopefully, THAT'S the problem ( or maybe a fuse or reset switch/button). The worst would be if the motor field coil windings burnt. Also, inside the motor, maybe the carbon contacts to the motor's armature may just need to be replaced.
Sep 20, 2012 | Breadman TR2200C Ultimate Bread Maker
Breadmaker not finishing the cyle
If you are leaving the unit plugged in all the time, you may reset it by unplugging it for about half an hour.  If this doesn't clear the problem, the timer unit is bad and will likely need replacement.  If you like the unit, consider a new one...or another brand
Nov 23, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman Ultimate TR2200C: "--H Error"
I had the same problem recently, however my machine was in use. I unplugged the breadmaker, let it sit and cool. After 1/2 an hour, It was functioning properly. If this doesn't solve the problem, after plugging IN try holding STOP/RESET button for 3-4 seconds.
worth trying...
Oct 20, 2008 | Breadman TR2200C Ultimate Bread Maker
Help
I would suggest you go online and order the instruction manual. I hacve done this several times with yard sale electronics. Go to the website for the manufacturer and you can usually get the manuel for less than $10.
Aug 21, 2007 | Breadman TR2200C Ultimate Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
178 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
