Question about Canon NP 6035 Copier
Shadows along the top of 11x17 paper
I write and print resumes and cover letters for a living and recently, I discovered a shadow along the very top of my 11 x 17 parchment paper. If I lightened the exposure, it went away, however, as I kept lightening it, the line came back. My repairman says I need a replacement copier. I bought some toner and it went away, but now it is back. What should I do?
NP 6330 Copier
  • egypt552 Mar 27, 2009
    i need to know how many mirror under the scanner to clean it all
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Did he clean the optics???
Canon copiers are susceptible to dust in the optics.
1-turn off copier
2-remove glass
3-pull scanner to the middle (gently)
4-clean mirrors w/lint free cloth be gentle -you do not want to displace the mirrors
5- remove the black metal plate that covers the lens to get to the other mirrors
6-put everything back
Posted on Oct 15, 2008
11x17 paper isn't printing properly
Check your printer manual to see if there is special setting for the 11 X 17 paper that you are using. If printers are not set up properly you can have hassles under certain conditions.
Aug 27, 2015 | Office Equipment & Supplies
While taking a print or photocopy shadow is coming on the center of the paper
My printer printing shadow behind all the letters
f you are running the printer's Full Feature Software, go into the Solution Center in the Toolbox and look for a way to clean the cartridges and / or print heads. Do it twice. It uses a bit of ink, but it will get any extra residue drifting around on the nozzles.Your printer's Webpage:
HP Photosmart C4795 All-in-One Printer
Look on the Menu (on the Printer) for the Alignment test. This may also be listed in the same area in the software section where you find the "clean cartridges" option.
General Instructions (may vary):
Align the print cartridges
The printer automatically aligns the print cartridges after a new print
cartridge is installed.
You can also align the print cartridges at other times to ensure optimal
print quality.
To align print cartridges:
1. Load Letter or A4 plain, white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Print Cartridges.
4. Click Align, and then follow the onscreen instructions.
Jun 24, 2015 | Kyocera FS-1035MFP
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
I have an hp2430, it is pringinting shadows along the left edge of the papers and a line along the right side. I have printed a cleaning page 3 times and replaced the cartridge, running the cleaning page...
the line could be caused by a scratched DRUM unit or a contaminated trasfer roller... And the shadow is probably a broken MICA ROLLER in the FUSER,
To get rid of the line (if the drum is OK) you need a mantenance KIT for that model, (pickup roller, transfer roller, separating pads etc...), for the shadow you need a new FUSER
Cheers!
Mar 22, 2011 | HP LaserJet 2420 Printer
Hi My printer 2600n prints a shadow of the
if logo preprinted may not take heat if everything repeats check fuser
Jul 28, 2010 | HP Color LaserJet 2600n Printer
Shadow along edge of my SHARP DM-3551 copier's copies
Run a page with the cover or document feeder open. Just a solid black page. If the shadow runs completely edge to edge on the paper, your problem is in the drum unit or less likely the fiser.. If the there is a clean edge delete, then the problem is either dirty scanner mirrors or the laser. It is far less likely in the optical/laser system but still likely. I tend to believe the problem is in the drum unit.
Mar 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
Shadowing on ACER AL1711 17" LCD Monitor
Did you ever find the problem with this unit? BTW, a crappy video cable can cause this or the input impedance has changed on the monitor due to improper connections.
Oct 28, 2007 | Acer AL1711 17" LCD Monitor
Shadows appear when printing out
Heating unit (fuser) 's teflon roll is dirty causing ghosting. Either replace with new heating unit (it is on front top near paper output) or clean it.
It can be cleaned carefully with electonic cleaning spray (non grease) WITHOUT using any force (be patient) wiping with cloth and spraying again and again utill it is clean. Then spray silocone spray to cloth and wipe teflon with that.
Open unit: Remove mains and usb/network leads. Remove paper holder (printed papers) from top back. Under that you'll see small arrows on both sides. Push screwdriver to hole and release locks. After that you can raise dark lid from top. Under that on white lid there is 4 screws, open them. Open all back cover scews and take the cover out lifting from bottom edge. Open 1 screw from right cover (where network socket is. Lift white top cover a little bit and then you can open right side cover (from back to forward). Under cover there is flat cable coming from display unit. Open it and then you can remove top white lid. Push the rest of dark paper holder backwards (on top) and it opens and you'll see the power supply under that. When looking from back there is 1 screw at right holding black plastic roller plate. Open the screw and bend the plate to left (looking from back) Now you can see 50% of brown teflon roll that is around the heater lamp. Clean it with spray and cloth pushing CAREFULLY from bottom to top.
Do NOT push teflon horizontaly as there is nothing on back of teflon and it may broke. Underside there is a metal plate under teflon and you can use LITTLE force for wiping. You can rotate teflon pushing white gear at top (from top to bottom, it turns only this direction). When totally clean, wipe with cloth sprayed with silicone spray.
I do not know how long this helps (just did it by myself) but the printing result is perfect again with same color casettes than before.
Sep 13, 2007 | HP Color LaserJet 2600n Printer
Canon NP 6035 Copier Logo
80 people viewed this question
old marine
old marine
