Question about Mitsubishi Televison & Video
I have a LVP-HC3000 DLP projector. I bought it new, I use it for sports and movies. It is 2.5 years old but it has <1500 hours on it. I do run it in "brightest" mode as do not have great control of light. It will not start up. When I press power I hear soft rapid clicks for about 5 seconds and the fan slows. It repeats this 3 times then shuts down. The lamp never turns on. I reset the lamp time to see if it would start up. It still won't start. I do not remember if there was a flashing green / red status status before (per manual indicates lamp need replace) but I never saw a warning on the image about lamp life. Is this as simple as replace the bulb? Thanks, Ben
  • bdbringardne Oct 15, 2008
    Sorry, this is a Mitsubishi product. I forgot to add that. Thanks.
    Genius:
  • 2,920 Answers
The bulbs arent hard to change but run about 100.00 have you checked the filter on it to see if it needs cleaned> its either on the back ot the side of the machine.i have one here too that i use and never an issue with it
Posted on Oct 15, 2008
Denon avr-1312 receiver and mitsubishi hc3000 projector - Video keeps dropping out
Hi, it could be a number of things, go to your browser type in the model followed by support, look at there info, is there enough life in the bulb? if it were mine i would clean the shutter and go on from there but try that what i have said example >>.denon avr-1312 support << hope this helps :)
Nov 30, 2013 | Mitsubishi HC3000U Multimedia Projector
Mitsubishi lvp-s290u turns on and works for about an hour then turns off
Give it a good cleaning while off with canned air. Be sure to clean filter if it has one. Do not spin the fans too fast or they will lock up.
Oct 16, 2012 | Mitsubishi Lvp-s290u Lcd Projector
Total Expected life (in hours) of a Panasonic DLP Projector
The projector lifetime has a lot to do with maintenance and environment. Over time, the LCD panels will start to deteriorate. I worked for a rental company where these units were in constant use. After 5 years, they were still going strong. Realize though, that these were highly maintained: constant cleaning via compressed nitrogen to remove dust, lens cleaning and filter changing on a regular basis. Checking for proper fan function and complete disassembly and checking for connections etc.
A word of caution: DO NOT work with the LCD block unless you have access to a clean area and have training. The tolerances here are very small. Slight changes can severely alter the picture quality and all adjustments should be left to a professional.
Hope this helps,
Dan
May 11, 2010 | Panasonic PT-D5600U DLP Projector
Road pro 1500-red fault lite blinks and has no power
unfortunately, this is a projector post. all i can say is that there is an issue with the inverters. return them to the store that you bought them from and get the next size up.
Mar 29, 2009 | Christie DLP PROJECTOR, SXGA+, 14000 ANSI,...
Color shifting
this common to dlp projectors! THe DLP wheel has a problem.it has lost its alignement
the best way to solve this is to gt a new dlp wheel replacement
Feb 08, 2009 | Sharp XR-1S Notevision DLP Projector, 800...
Optoma H30 Projector: color banding
Most DLP projectors have a colour wheel. It's usually hard to get at, and you may have to actually remove everything including the optical block from the projector to access it. This wheel turns on a motor just like a fan, and if it gets dirty it can act up just like a fan.
They are expensive to replace, so you might want to try taking it apart and cleaning it out. Add a small amount of 3 in 1 oil to the motor if you can.
Aug 22, 2008 | Optoma H30 Multimedia Projector
Dell 1200mp
Hi jezzwhizz
You'll see that at the back of your Projector there is 2 VGA ports 1 in (normally blue) and 1 out ( normally grey ).
You are most probably using the grey one , switch it to blue.
May 06, 2008 | Dell 1200MP DLP Projector
Mitsubishi HC1500 DLP Projector
This sounds like an overheat issue and requires return under warrantee.
Oct 06, 2007 | Mitsubishi ColorView XL30U Multimedia...
Televison & Video Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
