FixYa.com
Tags:
Compaq 2Mbps Wireless LAN PCI Card for Desktops
Intranetware Client for NT and RCONSOLE
By 2Pansy - usenet poster
I am having problems running RCONSOLE (or any apps that use SPX) on an
NT 4.0 workstation with the Intranetware Client for NT on a NW 3.11
network. I don't "see" any servers in RCONSOLE. I can connect to the
network OK and am able to access files and printers.
|Doug Dockter
|e-mail:
|Phone: 217-241-6317 Fax: 217-241-6579
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 28, 2006
Not Rated (0)
Duke
Duke - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Look at the properties of the Client32 in setup -- there's a section for
advanced options (or something like that - I'm at home and have
forgotten). One of the settings you can change is 'Minimum time to
net'. It defaults to '0'. I had the same RCONSOLE problem recently and
set that pram to 2500 and viola - problem solved. The text associated
with this param recommends a setting of 10000 for 2400 baud connections
and slow WAN links.
Bill
Ian Wood - Remove trailing 'x' from address to reply wrote:
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Cato
Cato - usenet poster
Rating: 0%, 0 votes
In article <01bc39f4$4d316ee0$010aa8c0@wrkstn_ep>,
says...
So it did work on 4.10? or only on 4.11?
I am going to set up a test environment to see if the problem shows up
there as well. I'll post back my results.
--Ian.
Solution #3
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rating: 0%, 0 votes
Ian, thanks for your reply.
My network is fairly simple but does tend to go through various changes
(R&D etc..etc).
Here goes...
Server
Clone 486DX2/66
Previously Netware 4.10 (fully patched), now Netware 4.11 (fully patched)
10BaseT (frames 802.2, Ethernet_II)
IPX and IP protocol over single NE2000 compatible
Workstation
Clone P166
Windows NT Workstation 4 (patched with SRVPK2 and Kernal/RAS hotfixes)
Latest IntranetWare client for NT (recently added, previously using
NTENU_N2.EXE)
Single SMC100Mbit PCI Ethernet card, previously NE2000 compatible
IPX and IP protocol over single adapter.
Windows networking also installed.
That's it really. Most things are pretty standard, nothing fancy. RCONSOLE
currently works locally (and always has done!) but not over DUN.
Actually, I've just noticed a small funny...
Whilst experimenting I notice RCONSOLE *sometimes* reports an error between
the point where you select SPX and then get the server list. Can't see the
error though, flashes away too quickly. Blast !
Still get my servers though!
Don't know whether this info helps...
Kind regards
Elliot Paterson
DST Business Systems +44(0)1270 886111
<> wrote in article
<MPG>...
Solution #4
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rating: 0%, 0 votes
In article <01bc39ca$a943c860$010aa8c0@wrkstn_ep>,
says...
As am I! But, if you din't mind, let me pick your brain for a minute and
see if there is a difference between your setup and mine. If you could
give me some details on your network. Here are mine.
Site A
Compaq ProLiant 1500 server with Netflex II NIC.
Novell 4.1 server 50 user (fully patched). Btrieve 6.15.
10BaseT Ethernet network (running 802.2,802.3,Ethernet_II).
IPX and IP protocols. RIP and SAP. No NLSP.
3Com Multiprotocol bridge/router connected to our 2Mbps WAN.
Compaq Deskpro NT Workstations with Netflex III NIC.
Both Intranetware client and MS CSNW. Both using NWLink.
Also Windows 95 and DOS/Win Clients.
Site B
Compaq ProSignia 300 server with Netflex II NIC.
Novell 4.1 server 20 user (fully patched). Btrieve 6.10c.
I am stumped by this problem as is Novell for the time being. Hoepfully
they will find something in the traces I have done.
--Ian.
Solution #5
Not Rated (0)
Bomber
Bomber - usenet poster
Rating: 0%, 0 votes
This is really weird.
I've noticed the various messages from people concerning RCONSOLE on their
local networks ... I've always run it completely fine ! Netware 4.10/4.11,
current intranetware client for NTWK4, previous client, no problem at
all... no special tuning, just default everything - no problem locally !!!
HOWEVER ...
I have this problem accessing my customers sites via DUN where their
servers run Netware Connect. RCONSOLE brings up an empty list ... specifing
the network address doesn't help, neither does specific frame types etc
.etc .. can't get that working at all !! Works okay from Win95 DUN...
Weird ?
I'm confused !
Regards
Elliot Paterson
<> wrote in article
<MPG>...
Solution #6
Not Rated (0)
Joey2
Joey2 - usenet poster
Rating: 0%, 0 votes
This could actually be a bigger problem than it sounds. I have had the
same experience. SPX on the local network does not work from an NT
client. I have been working with Novell on this as an open issue and they
still have yet to come up with a solution.
It is a wierd situation however. The only thing that doesn't work is SPX
from any NT machine to the Netware server on the local net. A server on
the other end of our WAN is accessible. DOS workstations can SPX to the
server in question.
With Rconsole do you get a server list when you choose SPX? If you type
in the internal address using <INSERT> can you access the server? Or do
you get an SPXEstablishConnection Table Full error? That is what I get.
I have done traces with Lanalyzer and found that NWLink is not addressing
the local server properly. It is attempting to send SPX packets to the
server's internal address as opposed to the MAC address of the NIC. So
the packets go out but nothing recieves them. Whereas the server on the
other end of the WAN has its packets delivered properly by the routers
and that is why SPX works to it.
It is not just the Intranetware Client. It is the MS Client as well since
they both use NWLink. We have tried anything and everything. Servers are
completely patched up, set the frame types on client, increased SPX
timeouts, etc. etc.
Let me know if your experience is similar or not. I will post any other
findings on this that I come across.
--Ian.
In article <>, says...
Solution #7
Not Rated (0)
Riddle
Riddle - usenet poster
Rating: 0%, 0 votes
I haven't tested as extensively as you have, but my problem sounds
exactly the same. I cannot access the servers if I type in the internal
network address in RCONSOLE. No resolution on this end yet.
|Doug Dockter
|e-mail:
Solution #8
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
I was having the same problem with RCONSOLE 3.75 (3.x version) and 4.10.
I uninstalled, re-installed, etc but to no avail. On Sat. evening I
realized that since it only happens on the Novell IN client32 that I can
probably 'tune' it.
The changes I've made are; select a specific frame type and specify the
correct IPX net number in the properties area for the IntranetWare
client, I also set the 'minimum time to net' param at 2500. I rebooted
and can now go into RCONSOLE (either version) and get the server list.
My guess is that the 'minimum time to net' param has more to do with it
than specifying a frame type (not auto-detecting).
Bill
Solution #9
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
I'm seeing the same stuff... NT wks 4.0, SP2, NW Client32, RConsole 4.10
or 3.75 ande no servers listed. I had it working a couple weeks ago then
had to do a re-install when a disk died. Thinking about it, I also had
several 'hot-fixes' installed (post SP2 fixes). I'll give that a try again
and report back. If anyone has any other ideas please post them. This is
a weird one...
Bill
EAJG Conijn <> wrote in article
<332DA>...
Solution #10
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
Doug,
I'm having the same problem as you, just installed the "new" v4.10
(02/14/97) Intranetware client for NT, and now can't "see" any servers in
RCONSOLE from a Netware 4.1 server.
This problem did not occur with the v4.00 (11/04/96) version of the
client. Must be somthing in the new Intranetware client software that is
messing up the SPX connections.
PS: You still can connect to your server via RCONSOLE if you type in the
IPXnet address.
Alan
In article <332DB95B>, Doug Dockter <> wrote:
"A programmer is a person who turns coffee into software."
Alan R. Vidmar Network Analyst/Administrator
Alan.Vid@Colorado.EDU University of Colorado
** This message printed with 100% recycled electrons **
Solution #11
Not Rated (0)
Janice
Janice - usenet poster
Rating: 0%, 0 votes
Thanks for the quick reply. I am using the lastest Intranetware Client
for NT and also have SP2 installed. I am using RCONSOLE 4.10. Is there
a later version?
|Doug Dockter
|e-mail:
Solution #12
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rating: 0%, 0 votes
Hi Doug,
Try a newer version of RCONSOLE.
I use the version which comes with Netware 4.10 and it works fine both
for 4.10 servers and for 3.12 servers.
Furthermore use the latest Client 32 for NT and use the Service Pack 2
for NT
Gijs
Can you Help with these Wireless Adapters problems?
Wireless Adapters
Asante Areolan AL1611 PCMCIA...
The Asante Areolan AL1611... Answer This...
Wireless Adapters
WMP55G
hi , i am using rhel 5.0. i... Answer This...
Wireless Adapters
Wireless card suddenly cannot...
My Buffalo wireless card has... Answer This...
Wireless Adapters
Ran
no logro bajar los draives de... Answer This...
Wireless Adapters
The microsoft wireless adapter...
Hi, I have a home network with... Answer This...
Repair Service
Find Wireless Adapter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
