Question about Microsoft Windows 98 for PC
Looking for data on the floppy
I have win 98. When many applications are started or when they are in use, like filling some areas with data, while positioning the coursor on the screen the computer needs time to do that and in the same time it is looking for data on the floppy. That slows down the system. What do you think that is the problem and how to fix it.
And I have another question, I have TakeMS Mem-drive Easy II, usb drive and I do not have driver for it. Can you point me where I can download it from?
Thanks, Snezana
    Genius:
  • 1,605 Answers
First of all you need at least 512MB of memories min. to run. majority of the program are gear toward WIndos Xp or Vista.
to fix the problem you have, is to deleted all of the temporary files (temp folders, Temperary Internet File folder). from the machine. and have at least 25% of the hard drive free. do a defregmentation.
next go to BIOS at the machine startup and disable the Floppy.
Like I say before, you may have porbelm locating USB driver for the Win98. the most you will have is USB 1.0 not the updated USB2.0 driver. which means there are only few USB enable device can be used.
Posted on Oct 15, 2008
Where would I get a reboot floppy disk
Unless you are running Windows 98 or earlier, there is practically no way to get the OS boot files on an area the size of a floppy disk. And I can almost guarantee that since Win 98SE even Microsoft has not put out anything on floppy disk.
Nov 14, 2016 | Computers & Internet
Mitsumi D359M3 driver for Win Wista, 7
You shouldn't need one. You PC bios should pick up the drive when you turn your PC on.
Look in "My Computer" the floppy should be listed there.
Floppies only hold about 1.44 Mb of data Its worth mentioning that these drives are more or less obsolete now, flash/USB drive hold much more data, more now than CD's (700Mb) and
DVD's (4.7 Gb) and now with SD card usb adaptors almost as much as Blueray disks (25 Gb)
Aug 26, 2011 | Mitsumi (D359M3 SILVER) Internal Floppy...
I have a problem with my fujitsu computer. The bios battery was out, the harddrive and cd didn't work. I put in a new Battery, HD and CD and installed win 98 se. Then I found out that neither the floppy or...
Hello user!
Back up your data and format again your computer but this time navigate to cmos setting by pressing del or F2 and select the optimal default setting and press F10 enter. Begin installing your O.S.
I hope it helps
Thanks
Nov 10, 2010 | Biostar M6TWG (M6TWG-V1.2) Motherboard
250 GB Western Digital external HD not detected by Win 98 SE
If you installed SE on Win 98, then here is a link to a generic USB driver that should work with your HD. If at some point you decide to install a newer OS or go dual-boot, you can always partition the HD so you don't lose any storage. Best of luck.
Greg
http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
Jun 14, 2009 | Western Digital WD Passport 250GB Portable...
Operating system not found
get a win 98 boot disk. get to the bios and enable floppy drive or usb floppy boot first. insert disk and turn on the computer you should get a menu screen select start with out cdrom support when you get a command prompt type FDISK MBR. this will repair your master boot record remove disk and reboot. or the hard drive is not plugged in or you may need to reinstall the OS again. if you reinstall the OS be sur to get the info off of your drive before you do it. it will erase existing info and make it really hard to recove that data.
Jun 10, 2009 | Compaq Presario 700 470024-192 Notebook
HELP
Are you trying to upgrade 95 to 98SE or just new install of 98.
What you may have to do is
  1. insert win 98 boot floppy
  2. boot with cdrom support
  3. at the prompt change to cd drive E:\ (press enter)
  4. at the E:\ prompt type cd Win98 (press enter)
  5. at the E:\Win98 prompt type format C:\ (press enter)
  6. confirm all data will be erased
  7. reboot with floppy in and at the a:\ prompt run FDISK to see if the full size of the hard drive is available. (option 4)
  8. If everything is normal exit fdisk reboot with floppy, choose with cdrom support, type in the cdrom drive letter (usually e) and cd Win98(change directory Win98)
  9. at the win98 prompt type setup (press enter) and follow the prompts.
May 30, 2008 | Compaq Armada 1500C Notebook
Window98 speed on net is very low
hi, easiest solution is upgrading your win 98 to win xp, 2nd:free space on your disk drive by removing unnecessary programs or applications to free memory space...also by delting temp files n cookies in your browser...i hope this helps, please feel free to ask if you need further assistance..good luck
Nov 28, 2007 | Microsoft Windows 98 for PC
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
3.5 Floppy drive
Hi, i have installed thousands of Internal Floppy drives and there aint no conflicts between win/95/98/me and xp. all discs should be compatible, unless you took it from a apple machine for example. did it work when you put in a new floppy drive? all the best John
Feb 21, 2007 | Teac Floppy Drive 235HF Internal Floppy...
Microsoft Windows 98 for PC Logo
76 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
