Question about Panasonic AG-456 Camcorder
This camera is making a sound when recording and also the lens has devloped some fuzz inside. Please let me know where they can service and clean lens out. Also I need an to purchase a new battery. Thank you for your time. Angela AG-456up Viedo camera
I have a panasonic ag 456 professional camcorder and when i record and play back it have an shreaking sound that i just cann't get out. Can this be fix or if the if it do have bad bearing.
Posted on Oct 22, 2009
    Champion:
  • 221 Answers
The sound you refer to during recording on the ag-456up is probably bad bearings on the video head. unfortunately, this part is no longer available. any good electronic repair shop should be able to clean the lens. a new battery should be available from wal-mart, circuit city, best buy, etc.
Posted on Oct 23, 2008
Dirt under lens
If this is a separate piece that is screwed onto the lens, then you may be able to remove it and carefully remove the material and replace the lens cover.
Aug 01, 2012 | Samsung SL620 Digital Camera
Error 99 and jerky fixation of focus between 17 and approxinately 30 mm works perfectly at zoom lengths beyond this with normal rapid fix of focus and records image normally. the error and failure to...
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
For the jerky focusing ring, you need to get the lens serviced by an authorized service center.
Aug 28, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon ixus 70 all showing a fuzzy dark spot??
clean the lens,get it serviced the lens as well as CCD.
Apr 10, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My GR-X5AA says "Lens Cap" when turn on camera.It comes when lens cap remove from the lens also.But i can't take still images and record a vedio.I can play recorded videos and images.Please help me.
Your camera lens has a problem. If you have background repairing such. Try to open and clean the iris curtain(shutter) with methyl alcohol or any other alcohol base cleaner. Must be open and bring those curtain out to clean it effectively. Otherwise have it checked by JVC Service Center near you. Good luck
Mar 02, 2010 | JVC GR-X5U DV Digital Camcorder
A grinding sound coming from inside the camera (PanasonicHVX200A)
If noise occured during while OIS function is on,then must lubricate the axis inside lens underneath the ccd block.Due to friction of the movement of the coil used for moving lens for optical stabilizing function makes noise,but if this is not the problem, camera board must be next suspect,so first clean and lubricate and after ask service for cost.So generally speaking ,the problem is on the lens unit ,or the camera board which drives it...
Jul 15, 2009 | Panasonic AG-HVX200A Mini DV Camcorder
Fuzzy dot
Hi
Its hard to say without seeing the camera myself, but it's either dust inside the lens or it could be a small amount of condensation that has dried up and left a small amount of dirt behind.
What you will need to do (or have somebody do) is open up the camera, tear apart the lens and see if there is any dirt on the CCD. You can also look inside the lens from the front and see if you see any dirt trapped inside.
If you see dirt trapped inside the lens.... The only solution I know of is to replace the lens. If it's on the CCD (behind the lens) it's easy to clean off. Just make sure you don't leave fingerprints on the CCD when you're cleaning it.
If you need somebody to do it for you, we are a digital camera repair business (Google Darntoothysam) and would be happy to help. I think we have a CCD cleaning listed for about $35 including return shipping of the camera, but please note as I said above if its inside the lens elements and not on the CCD we can't clean it off.
Hopefully this advice helps, and if you need to ask further questions please feel free to contact me.
Good luck from Darntoothysam com
Thomas
Sep 20, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Fuzz
clean the lense.then lick my arse
Jun 25, 2008 | Nikon D200 Digital Camera with 18-200mm...
Recording
The microphone on most of these slip cameras are very small and it is possible your finger or hand was over it. And to be honest since this microphone is so small the quality is not going to be very good at all. I don't know if there really is a solution to this outside of buying a high end camera if sound quality is so important.
Aug 11, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Panasonic AG-456 Camcorder Logo
159 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
