Question about Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10US won't spin
I have a Fisher Paykel GWL10US. Today it stopped on the spin cycle and didn't fully drain (about inch or so of water left).
If I manually put it in spin cycle the drain pump spins forwards and backwards. So does the agitator. Water just seems to sit there and foam up, but doesn't drain.
Here is what I have done:
Took out wash tub to see if drain was clear. Took off drain housing. Did find a piece of chewed up plastic in the drain housing. Doesn't seem to go to anything from the washer.
Took off pump motor to make sure it spun freely. It does.
Took off diverter valve to see if it is stuck. It is in drain mode with the power off. Can push the valve with my finger to open and close.
Snaked out the drain hose.
Put machine in diagnostic mode.
- Water valve test. Fine.
- Out of balance and lid switch test. Fine
- Drain pump test. Same as above. Pump spins back and forth and just seems to foam up water.
- Detailed Fault Codes: none.
Any suggestions?
Thanks
  • 46 Answers
Hi
if the pump works fine in diagnostic mode then it has tobe a module problem
cheers grant
Posted on Oct 21, 2008
My GWL10us will not go into spin
Hi just read your posting.Now just a couple of question,Is the machine draining the water?Is the machine stopping completely and beeping? Please reply with additional information and I am sure I can help you.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel GWL11 Top Load Washer
Warning I have too many suds
Hi just read your posting.Now just a couple of questions.1st where is the machine draining the water to?Is it into the laundry sink or to another place?Have you removed the clothes from the machine?Have you tried putting a bucket or two of water manually into the bowl and put it to a spin cycle to drain the water out? Please reply with additional information and I can help you further.
Jul 06, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Help
YOU NEED TO CHECK IF THERE IS NOTHING STUCK IN THE PUMP AS NOT DRAINING ALL THE WATER IS A SIGN THAT THE PUMP IS NOT DRAINING COMPLETLY.GOODLUCK. MOHAMED
Sep 18, 2008 | Fisher and Paykel IWL12 Top Load Washer
I have a gwl10us
First check to see if water flow is good at your wall faucet, coming into machine.
Then check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (maximum 7 inches). Snaking out your standpipe would be good too.
Jun 05, 2008 | Fisher and Paykel Washing Machines
FisherPaykel GWL10US won't spin
diverter valve malfuntion water is recirculating instead of pumping out
May 28, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel GWL11 Top Load Washer Logo
513 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
