No sound and no display lights in the front panel when turning the key but all the other lights, turn signals, horn, AC worked fine. So replaced battery and ignition system. It runs with jump cable start for a couple of days then next morning same problem. Any solution & idea will be appreciated.
SOURCE: 1996 nissan sentra
Find the big hose that comes out of the top of the radiator and follow
it to the engine and that is where the thermostat is located. My
advice is to be sure to get a factory thermostat and rubber gasket as
it makes installation much easier. I have done it both ways and the
factory one is easier to install.
SOURCE: Starting problems 1998 Nissan Maxima SE V6
Hey there, I would look at the switch on tha back of your ignition. Not the ignition it self, but the switch that's on the back of it. Its white round looking thing about 1 1/2 inches in circumference and it has wires coming out of it. I think that its gone. If you are sure, that your battery and battery connections are OK, than look at that switch. Part is replacable at about $50bucks for the part and than if you can put it in your delf, thsm you will save some money there too. Good luck
SOURCE: I can barely hear my horn.
It is probably clogged with dirt and water. Either pull the old one out ant clean it or just buy a replacement horn. These are really easy to install, the hardest part is trying to find where the horn is.
SOURCE: 1991 Nissan Sentra will not start...
i had the same problem with my 91 i did all the same stuff you all are doing all it ended up being was a bad ground. try using jumper cables from your ground post and see if you can get better ground. hope it works for you
Ken, I would have the alternator checked.
Check the alternator
