Question about Asrock P4I45GV R5 Motherboard
Display problem after Format
Formatted with xp but the Monitor wont show. It only displays 'sync out of range' I'm really gettin nervous cos i nid my system back on.
    Scholar:
  • 31 Answers
Hi, my name is Alex and im here to help sort your problem out.
It sounds to me like you need to change the herts configuration of the monitor and also the resolution you have your monitor set to. It should be set by default to 60 herts. Also, the resolution is best set at 1024 x 768. To set these, you need to right click anywhere on the desktop and click properties
To change the reolution.
Click start, configuration, display. Slide the cursor until you display 1024 x 768
To change the herts.
Click start, configuration, display, advanced options, monitor and make sure it is set to 60 herts.
I hope this helps. Please let me know if you experience more problems.
Posted on Oct 15, 2008
  • Alex Woods
    Alex Woods Oct 15, 2008
    Does the boot screen come on? If so, you need to enter Safe mode by pressing F8 before Windows boots. When you enter safe mode, the screen resolution will be big but at least you can change the herts configuration.
    I hope this info is useful to you.
I Just Formatted My System With Windows XP Service Pack 3 , My Displays Are Not Clear ,Its In Blur State.
If you mean the displays are kind of fuzzy at a partiuclar resolution, try changing the refresh rate. Whenever you install XP, refresh rates default to 60 Hz - this is rarely the optimum for the display. Most displays operate best from 70-75 Hz or possibly higher. Right click on the desktop, observe DISPLAY PROPERTIES window. Select the SETTINGS tab, highlight the display you wish to modify, then click the ADVANCED button. Select the MONITOR tab. Use the SCREEN REFRESH RATE pull-down to select the refresh rate you need. Be advised, if you select a rate the monitor cannot handle you will lose visual on the display and could damage the monitor. You can avoid this by selecting the "HIDE MODES THAT THIS MONITOR CANNOT DISPLAY: check box.
Jan 02, 2012 | Intel Computers & Internet
Tip
Fixing 'Out of range', 'Format not supported' message
When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur:
Sync out of Range, Out of range, Format not supported
SOLUTION (FROM HP):
To avoid the message, lower the resolution or vertical frequency of the video card.
Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
1. Shut down and restart the system.
For consumer systems such as HP Pavilion desktop PCs, push the Power button once.
For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
3. Scroll down to highlight Enable VGA Mode , and press ENTER .
4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor. Reboot
Resolution adjustment:
From Microsoft: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx?mfr=true
and here:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
and here:
http://www.videojug.com/film/how-to-change-screen-resolution-in-windows-xp-and-windoiws-7
on May 21, 2010 | Computers & Internet
How can I fix an "Out of Range" display?
Please reduce display resolution of computer/ laptop to solve "out of range" error because laptop is producing high resolution video signal and monitor hardware is unable to show that much higher display resolution so causing that error message.
Let me know what Windows version (XP, Vista, 7) is running in laptop to provide you more info or check Display Properties in control panel and change it to lower resolution to get picture in monitor.
Thanks.
Feb 09, 2011 | Westinghouse L1975NW Monitor
DISPLAYS ARE SIDEWAYS STRETCHED
This problem is because, when you formatted your PC, you have installed improper display driver of your PC model. This is also because of less capacity display/graphics card.
Jul 30, 2010 | Compaq Computers & Internet
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
May 20, 2010 | HP L1506 15" LCD Monitor
Getting a No sync message on monitor ,computer
No sync message could be for 2 reasons.
1. Loose VGA cable
2. Wrong driver installed or configuration made is out of monitor range
For loose cable you can fix it up from both ends, on CPU and on Monitor itself.
For second reason, we just have to delete display driver from Device Manager. Follow below method to delete driver
Start computer in safe mode. To start in safe mode, as soon the system boots up press F8 and select Safe Mode. After you log into the safe mode. Right click the "My Computer" icon on desktop, go to properties,
go to "Hardware" tab, Click on "Device Manager", go to "Display driver" and expland it, select the driver below the expanded "Display Driver" and press delete to remove the driver. Now restart the system and it will automatically adjust the display driver for you.
May 15, 2010 | Microsoft Windows XP Home Edition
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
Display sync out of range
start the computer in safe mode.
go to control panel>>display>>settings>>advance.
reset the screen refresh rate back to 60Hz under the monitor tab.
Nov 17, 2008 | Mercury KVM266PM-U (KVM266PMUD1600)...
Sync out of range
If using windows, boot to safe mode, and make sure your resolution is low enough for your monitor to handle.
Check your cables to make sure there are no broken pins.
Sep 16, 2008 | SAMTRON 55V 15" CRT Monitor
Defect ASUS V8420 ?
I don't understand, please explain more:
0) What kind of a monitor is it ?
1) If the monitor is NOT plugged into a working video card,
it should blank out or display some sort of a
"NO SYNC" or "NO SIGNAL" or "UNPLUGGED" warning.
The power light may also flash or show a different color.
2) If the monitor is plugged into a working video card,
it should wake up from the inactive power-saving mode
and display the desktop.
3) If the video card is malfunctioning, or if the windows
video settings are set outside of the monitor's sync limits,
the monitor may turn off or display a warning message,
such as:
No sync, Out of range ... etc.
4) The repair situation (3), reboot windows into
safe mode:
a) Press Hardware Reset
b) After the power-on self-test (POST) and memory check
press and hold the F8 Key
c) Select Safe mode
d) Login to windows at low resolution
e) Right-click on the desktop, chose:
Properties -> Settings -> Set the correct resolution, apply
Click advanced -> monitor -> set the correct refresh rate.
Reboot normally
Hope this helps
Martin
PS, some monitors have dual inputs: VGA or DVI
make sure the correct input is selected, depending
on your cable (VGA is a 15 pin "D" connector,
DVI is a larger connector with many more FLAT pins)
Also some video cards have multiple outputs, which are
activated only if a correct monitor is attached BEFORE
reset.
Apr 22, 2008 | ASUS V8420/TD Graphic Card
Asrock P4I45GV R5 Motherboard Logo
70 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
