Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Thank you, it is fixed now.
Thank you for the idea of looking for low value resistors. I found R536 to be blown like you said for the below problem after I replaced the IC.:
have a Sony KV-27FS100 TV that has no picture, but I do have sound and can change channels. The indicator LED blinks 4 times then repeats. I'm told that this is likely a problem with IC561 (TDA8172).
  • 4,234 Answers
Happy to help. Thanks for the update.
Posted on Oct 15, 2008
The treadmill have dcmd67 control board I need to know what value resistor R 19 have
I can't help you (directly) with the resistor value, but be aware that if it exploded, there is probably another bad component (such as a capacitor, transistor, and/or an SCR). Replacing only the resistor may result in the same problem, or may not even work at all due to another bad component. If you do find out the value, try putting in a resistor of the same value, but with a higher wattage rating. I once had a washing machine in which the model had a known problem with circuit boards blowing. I solved it by replacing a bad transistor and installing a higher wattage resistor that had blown up like yours. It never failed again. The way I found the value of the blown resistor is, I looked up a replacement board online, then magnified the photo, and looked at the color code on that same resistor in the photo. How I found the bad transistor is too complicated to explain in few words, but you can google the procedure. (You'll need a multi-meter at the very least; preferably _with_ a built in transistor checker. However, a _totally_ blown transistor can be found with only the resistance settings on a regular multi-meter).
Best of luck...
Apr 05, 2016 | Exercise & Fitness
Denon AVR2106 One output channel shorted and blown. 2 power transistors shorted, emitter resistors and base resistors blown Have replaced all, including bias transistor I think bias is still wrong (no...
I would also replace 2sa992 (2pcs) and 2sc1845 on preamp board- sometimes they look ok when you test them by regular meter. Check 1.2 kOm and 4.7ohm resistors at preamp pcb. Check diodes on output pcb (could be smd type, connected from base of output transistors to emitter i think)
Sep 07, 2011 | Denon Audio Players & Recorders
R47 resistor is blown on Neff S5453X0GB/07 control board. I can't make out the value as it is badly damaged - anyone know the correct value so that I can replace it (TY7 is blown as well!).
HI.We cannot really but identify the correct resistor value unless we can identify or determine the color coding on the resistor.Each color has a corresponding value and tolerance as well.If you can't indentify the color coding then you can refer to its diagram usually printed out on the side of the control board or near thecontrol board.We cannot but cannot give a guess value unless color coding is given.Thank you for choosing FIXYA.
Aug 27, 2011 | Dishwashers
Black Screen One resistor is found Blown inside BWB but value unknown ! Please help !
Depending on the resistor, the values for a resistor is color coded, meaning that there are a couple of lines of colors and each color line represents a value. Do a google on Resistor coloring chart and you might find your answer. If the resistor is a surface mount one and very tiny, you might be out of luck as these are too small for the manufacturer to print the part number on. Only the manufacturer has that part number and can be very hard for you to contact them about.
Nov 10, 2010 | Acer AL1715 17" LCD Monitor
Samsung 52" HDTV red convergence bowed
First---look close at all the resistors around the chips--any that are white or discolored in the middle are suspect--MOST of the time a low value resistor (1.5, 1.8, 2.2 ohm) will be bad---check them all--there will be some 150 ohm or higher--they usually do not go--
There is a site I have found where you can download a service manual---I offer it only as information and not a solution-----
If you find an open resistor or resistors they all have a location number on the top of the circuit board in case they are burnt and you cannot tell value from the color bands marked on them.
Regards, SD TECH
Oct 06, 2009 | Hitachi 46F500 46" Rear Projection...
you can download your schematic that will tell you resistor values and the rest of the circuits and IC indentifications as well as test procedures and more , this is a ten part zip that can be opened with winzip and read with adobe just click here
then to order resistors you can get them here
or look for an electronic parts supply store around you , but alot of the time they too have to order the parts, ecspecially certain valued resistors or other special valued parts
if you need more help just ask !
Dec 11, 2008 | Hitachi 60FX32B 60" Rear Projection...
Lightning damage
Replace the parts with the original ones, a .5 ohm difference on a resistor on the video circuits will cause the unit not to work correctly.
Sep 27, 2008 | JVC HR-XVC27U DVD Player/VCR
Replacing Convergence IC's, I found a bad resistor needing replacment
They are both 1.8 ohm 1watt fusible resistors. Metal film 5% 1.8 ohm 1watt will substitue them
Aug 08, 2008 | Toshiba 50H71 50" Rear Projection...
Blown Channel on an amplifier
Look for low valued resistors that may look ok, but be open. Check the emitter resistors (.22 or .47 ohms). Check the transistors in the driver circuit as well.
Jun 06, 2008 | Denon AVR 3808Ci Receiver
Red, Green, and blue
sell it on ebay as broke they go for 100 just a idea look like u tryed alot
Feb 05, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
172 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
