DVD Player will not play
I have a GOTECH GTD 5200 DVD player. It is a "Play Only", very simple. Every time I put in any disc and press play or any other key on the rmote or on the device itself it reads"err disc" on the tv screen. I have used a cleaning disk, and I have cleaned the laser"eye" with isopropyl alcohol. None of this works. The player itself has been barely used, maybe 10 times in the past year since I bought it. It worked fine the last time I used it 2-3 months ago but even after mty attempts to clean it as other sites have suggested it still reads "err disc". I also have misplaced the instruction manual, however, it is a "play only". Any suggestions!?!??!!,
Thank You, Bob Frustrated.
5 Suggested Answers
SOURCE: Emerson PDE-2717 Portable DVD Player - worked great for a few months but now just says 'Bad Disc' even when using discs that work in other players.
Connect the DVD player and while it is off, press for 5-10 seconds the 'A-B' button. This will help clear the 'Bad Disc' memory. Enjoy!
Posted on Sep 29, 2007
SOURCE: we have a yamaha dvd player, model number dv-s5450
I had a similar problem...the machine, which had been great up until then, started to be very fussy when loading a disc; using a lens cleaner did not help at all.
I opened the disc tray and used a can of "air duster" with the straw attachment blowing in lots of air into every little nook and cranny that I could reach, especially in and around the actual lens area. The liquified gas under pressure must have been too cold as, at first, there was no improvement whatsoever when I tried playing a disc. However, the next day the player was working perfectly again.
It is worth a try.
Posted on Dec 08, 2008
  • 3 Answers
SOURCE: Disney dvd player wont play movies (dvd) but plays music (cd) fine
Might be the type of movie - some of them are only able to play "G" ratings. Try this: click <play> 1234 <play> It will likely unlock the dvd that is in and will begin to play. You will have to do the 'code' each time, or there's an unlock program you can purchase.
Posted on Feb 01, 2009
SOURCE: CD PLAY WON'T READ THE DISC
i HAD THE SAME PROBLEM, I BOUGHT A SPECIAL DISC FROM TV/RADIO SHOP IT COST APPROX £5. I HAD TO RUN IT 5-6 TIMES TO GET IT PROPERLY CLEANED. ,I WAS GOING TO THROW OUT MY PLAYER AS I THOUGHT IT WAS GOING TO BE OF NO USE BUT IT IS NOW PLAYING AS NEW,HOPE THIS IS OF SOME HELP.
JACKIE
Posted on Sep 16, 2009
Testimonial: "THANKS - I'LL SEE IF I CAN FIND THIS DISC -MAYBE RADIO SHACK??"
SOURCE: jvc dvd player no disc error
Hello!
I did have a similar problem. It was solved by cleaning the laser lenses/prisma. You have to dismantle the whole pick-up the to see the laser lenses.
There is one lens which is held by couple wires and below there is prisma/mirror.
I did use ear-cleaner-stick and desinfection liquid (with alcohol) for cleaning. Now it works!
Posted on Nov 27, 2009
URGENT! DVD not ejecting or playing.
It seems you will need to open the damn thing, or search for a tech, verify your warranty, dont void it.
First you can try to move a little bit the dvd, unplug and plug, change disc, ieverything that can move a part inside the dvd must be pressed, surely is stucked between the play and the open stage.
Jul 17, 2010 | Pioneer DV-515 DVD Player
I put an HD-DVD in my player but it keeps coming back out.
Temporarily you can hold the lid closed with your hand and press play and leave the lid after it loads the disc. But for permanent solutuion you will require to repair its lid switches,
Aug 22, 2009 | Toshiba HD-A30 HD-DVD Player
Does not play dvd copies
simple some actaully most portable dvd players just arent made to play copys or duplicates becaues they do not have the software for that kind of disc. so they instead can only play origanals dont worry my portable dvd player does this too
Apr 15, 2009 | Durabrand PDV-705 Portable DVD Player
Yamaha S661 Player wont play multi region
This one is for S530, S540, S550, S557, S560, S600, S657. It's worth a try. Tell me if it works.
  1. Open the disc tray
  2. Press 9, 9, 9, 9, 0
  3. Press ENTER
  4. Close the disc tray
Apr 13, 2009 | Yamaha DVD-S661 HDMI DVD Player
DVD PLAYER WILL NOT OPEN
I found the answer on your site. Unplug, wait a minute and plug it back it in, then press Play followed by Eject.
Mar 28, 2009 | Toshiba SD-2109 DVD Player
Recorded dvd
You are probably having an issue with the discs rather then what you are trying to play them on.
The discs need to be finalized before they can be used on another player.
  1. Put the disc in the drive (the ones you have already recorded)
  2. Press SETUP on the remote
  3. Select - Disc Edit Press OK
  4. Select - Finalize Press OK
Wait until it is finished then try to play them on another player.
Apr 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Player Does not play any type of Disc
Press case lid where it attaches to player. If this makes unit react you have a defective lid switch. You can probably put some weight over it to hold lid down and it will operate. Otherwise switch must be repaired
Oct 06, 2007 | Jwin JD-VD149 DVD Player
DVD player won't play certain movies
it could be the disc that is causing the problem try some other disc and see what it does.good luck.
Mar 23, 2007 | Memorex MVD2022 DVD Player
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
Electro Med Services...
