Question about Xerox WorkCentre M20i All-In-One Laser Printer
Xerox workcertre m20i
Hi i have xerox m20i printer, but the centrol control panel glass was broken, then it cause the buttons don't work properly. I am looking for the glass but just get no luck, please help.
I appreciate your great help.
Alan Lu
    President:
  • 2,072 Answers
Most likely not going to find just the glass. Go to google and search for " the parts drop" they will be the first item in your search. Call them and ask for Britt, he will work with you to get what you need at a very fair price.
Posted on Oct 15, 2008
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
How to print a configuration page on a m20i
We encourage you to use our knowledgebase, MRC Smart Technology Solutions is here to help! We offer a program to cover up to 3 printers of any manufacturer for an entire year!
We can solve your problem!
Email patrick@mrc360.com for more info.
Solution : Print a Connection Page (Network Connectivity Report / Configuration Page) NOTE: Print the Connection Page to locate the TCP/IP Address for the WorkCentre.
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Up or [Down] arrow button until 'Reports' is selected, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until 'Connect Page' is displayed, and then press the [Enter] button to print the report.
  4. Press the [Stop] button to return to the Standby mode.
http://www.support.xerox.com/support/workcentre-m20-m20i/support/enus.html
Oct 13, 2014 | Xerox WorkCentre M20i All-In-One Laser...
I have a H3 error code on a xerox workcentre Pro 215. What do I do to clear it?
This should correct it.
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
Dec 15, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Adjustment for light copies on a xerox m20i
You will need to do a couple of things, 1 remove, disassemble the scanner and thoroughly clean it, and while you have the scanner out, remove and clean the laser.
The toner cartridge may also be defective. that metering blade in that cartridge fails and causes light images also.
If you need instructions on how to remove and clean the scanner and laser let me know, I will type them out to you.
Not hard, just time consuming.
If you print out a report how does that look? If prints look fine and just the copies are light, then the mirrors in the scanner head a re probably fogged up. All the plastic in that scanner causes that same film on your scanner optics as you develop on your car windshield. Same process.
Jan 22, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox M20I SCANNER
You can only do scanning on an M20i with a USB or parallel cable. That machine does not support scanning via an ethernet cable.
Oct 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Broken Glass on a M20i
1. Oprn the front door, as if to replace the toner and remove the 2 screws above the toner and drum.
2. Turn the machine around. Disconnnect the one connector to the document feeder. A beige molex connector, lift and remove the feeder.
3. Remove the 6 screws from the back cover, remove the cover.
4. Disconnect the white ribbon cable and black connector with red wires attached to the upper part of the main board.
5. Under the scanner body, on the rear of the machine, locate the 3 screws that hold the scanner to the frame. One on the right, on in the middle and one on the left.
6. Grasp the scanner from the sides and pull back to release the scanner tabs from teh frame.
Once the scanner is removed you then have to remove the 3 screws holding the control panel to the scanner, then the 5 screws that hold the frame holding the glass. I am not sure where you can get that glass. But do a google search for "the parts drop". Give them a call, ask for Britt and see if he can come up with one for you.
Aug 11, 2008 | Xerox WorkCentre M20i All-In-One Laser...
FAX ERROR MESSAGE
It sounds like the fuser rollers are not at the proper temperature to work.
They should be inspected by a technician.
Jun 19, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Problemas a Imprimir, recuadros y lineas
Sounds like a dirty seal glass. Clean the glass on the left side of the scanner. The 1/2 inch strip of glass.
Feb 12, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
63 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
