Question about Troy Computers & Internet
87.002a EIO2 error
We have a Troy check printer and it has worked fine up to now. The display gives the following error: 87.002a EIO2 error. When this error is listed, you can not print checks. Once you turn the printer off and back on, it prints the checks and list itself as ready. After a little time passes (1-2 hours) it displays the error once again.
What do we do? HELP?
SOURCE: documents not printing
Thanks. My laptop can see the print server, as I see all my documents in the queue. (and I can also successfully ping the print server). It appears the HP LaserJet 1020 is just not supported... Looks like a return is in my future. Thanks. Digger
Posted on May 31, 2007
SOURCE: HP LP1020
It seems that I found an imperfect solution. When you intall the printer on your PC and print a testpage, the firmware is sent from PC to printer and is stored in the printers internal memory. When you unplug your printer from your pc and plug it in on your printserver it should work fine as the firmware has been loaded alraedy. You can't switch of the printer nor the printserver or the firmware needs to be uploaded again via your printer. There is no way at the moment to load the firmware upon booting of the printer by the print server. Hopefully this issue will get resolved in the near future.
Posted on Oct 03, 2007
SOURCE: Errors list : 46, 50, A1
CP315C/310CN/120C/115C/117C/110C
(1) Press the (1) Press the
Menu and Mono Start keys. Menu and Mono Start keys. Next press the key four times to make the machine Next press the key four times to make the machine
enter the maintenance mode. enter the maintenance mode.
(2) Enter 8 and 0 by using the and (2) Enter 8 and 0 by using the and
Set keys.* Set keys .*
(*To enter a numerical code on models having no numerical keypad, press the key several times to (* To enter a numerical code on models having no numerical keypad, press the key several times to
display the numerical code to be entered and then press the display the numerical code to be entered and then press the
Set key. Set key. Repeat this operation for each Repeat this operation for each
numerical code.) numerical code.)
(3) Press the (3) Press the
Mono Start key several times until the purge count appears on the LCD. Mono Start key several times until the purge count appears on the LCD.
(4) Enter 2, 7, 8, and 3 by using the and (4) Enter 2, 7, 8, and 3 by using the and
Set keys to reset the purge count to zero.* Set keys to reset the purge count to zero .*
(5) Press the (5) Press the
Stop/Exit key to return to the initial stage of the maintenance mode. Stop / Exit key to return to the initial stage of the maintenance mode.
(6) Enter 9 twice by using the and (6) Enter 9 twice by using the and
Set keys to exit from the maintenance mode.* Set keys to exit from the maintenance mode .*
Posted on Mar 06, 2008
SOURCE: Issues Printing with DPR-1260
This worked for me and I was having the same issues as everyone.
http://support.dlink.com/faq/view.asp?prod_id=2705&question=DPR%2D1260+vista
Before I put this solution in (manually adding the printer step-by-step), I could print a test page just fine, but not anything from Office.
Make sure to follow each step in order. I printed off the test page and held it up to the old one and the only thing I saw different was a field named "Shared". It was blank but who knows. I'm just happy the darn thing is working!
Posted on Apr 16, 2008
  • 3 Answers
SOURCE: Trendnet TE100-P1U won't print
open the print server utility and the doc can be cancelled or deleted from there. (this is the server utility inthe toolbar at the bottom of a windows screen. failing this go to the printer shortcut and from control panel>printers> select printer and faxes>select the printer (open) >select "printer" from menu bar, pause printing,then cancel all documents. Afterthis you can delete printers that are excessivly created, or delete all of them and start again with only the one or two printers you need. even if one is for network use and the ther is direct connect. You canuse direct connect to verify proper printer operation until te100 is working properly
Posted on May 10, 2008
Error code 55.4k
This error 55.4k appeared in printer hp color laserjet 5550. The following trouble shooting did. Orignally my printer fault is display blank.Then i replace dc board with formatter board. blank is gone dueto new ram.Machine display showed the memory process. but immediatly the error 55.4k appeared on display.The reason for this error is, communication failure between formatter and dc board.The dc board which i was replaced by old type one.Then i found exact same dc board, replaced. Error was gone.Machine came to normal status , working fine.
Oct 01, 2013 | HP LaserJet 5550dtn Printer
Troy 8150 Printer
Yes I beleive you do need the -P
I use this on a HP 8150 I think it is Aust.version of you machine from the look of it
lpr -S 100.100.10.111 -P raw -o c:\temp\output.ps
Getting print q name
Press Menu until INFORMATION MENU appears on the printer display.
2. Press Item until PRINT CONFIGURATION appears on the panel.
3. Press Select to print out a configuration page
2nd page should be listed your print que name
or maybe just type the ip address of printer in browser and look in printers webpage.
Sorry for sketchy answer just trying to help!!
Oct 31, 2007 | Office Equipment & Supplies
System error e000
Are you getting the error on your computer or on the printer display?
Jul 27, 2013 | Canon imageCLASS MF4320D
Cartridge Error - see user manual
It seems that you have tried most of the troubleshooting steps to identify and fix the problem. But try to replace your black cartridge with a new genuine Lexmark cartridge to determine if it's a faulty cartridge issue.
You may also contact Lexmark Technical Support Center for additional assistance.
Jan 24, 2012 | Lexmark X4650 InkJet Printer
Correct loading of ink cartridges. Error E2
When a printer error occurs, the Alarm lamp is lit orange. The number displayed on the LED indicates the type of error that has occurred. Check the error code displayed on the LED and take the appropriate action to correct the error.
E and number (error code) are alternately displayed on the LED of MP210 series.
Error E, 2:
Cause: The machine is out of paper. / Paper does not feed.
Solution: Reload the paper correctly and press the Black or Color button.
This sounds like to simple a solution. Make sure this is the correct error code and it is not followed by another number. If problem persists check that you have removed the protecftive material from the FINE cartridge holder. Unplug the machine from the power source for several minutes. Power up. Hopefully this corrects the problem.
If not, try checking the status of your ink cartridges:
1 Open the printer properties dialog box from Control Panel.
2 Click View Printer Status on the Maintenance sheet.
To confirm the FINE Cartridge information, click the Ink Details menu.
This my give further clues to any problem.
Trust this is helpful. :)
Dec 08, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Error code 6203, KODAK says it does not exist on
If that's the error code your computer is showing, it's not on their list. You need to give the error code shown on the printer display.
Dec 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
What is error code 300 for Canon MX310
Error Code 300 is displayed.
1) Cause : The machine not ready.
Action : Confirm that the power lamp is green.
If the power lamp is off, turn the machine on.
While the power lamp is flashing green, the machine is initializing. Wait until the power lamp stops flashing and remains green.
If the Alarm lamp is orange, an error may have occured on the machine.
2) Cause : Machine is not connected properly.
Action : Make sure that the USB cable is securely plugged into the machine and the computer.
* if you are using a relay device such as USB hub, disconnect it, connect the machine directly to the computer, and try printing again. If printing start normally, there is a problem with the relay device.
Consult the reseller of the relay device for details.
* There could be a problem with the USB cable. Replace the USB cable and try printing again.
3) Cause : Your machine is not selected in Printer on the Print dialog box.
Action : Select your machine's name in the printer on the Print dialog box.
If your machine name doesnot appear in Printer, follow the procedurebelow to check that the driver for your machine is installed on your computer.
a) Select Print & Fax Preferences in Printer.
In Mac OS X. v.10.2.8 or 190.3.x, select Edit Printer List in Printer.
b) Check that your machine's name is displayed in the list of printers and that the check is selected.
In Mac OS.X v.10.2.8, check that your machine;s name is displayed in printer list.
c) If your machine's name is not displayed, click Add(+) to add the machine. If you cannot add the machine, follow the procedure described in youe setup sheet to reinstall the MP drivers.
Nov 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    HP 4350 printer
    you might need to upgrade the firmware
    Dec 28, 2007 | HP LaserJet 4350 Printer
    Computers & Internet Logo
    128 people viewed this question
    Top Troy Computers & Internet Experts
    David Payne
    David Payne
    Are you a Troy Computer and Internet Expert? Answer questions, earn points and help others
