Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Mildew on rubber
How do I replace the rubber on the opening of my washer. Is't all moldy
Mine was under warranty and the door was replaced. That new door does not leak''''  as much!!!!!
Posted on Oct 23, 2008
Moldy mildew smell won't go away.
When I get the mildew smell , I run the machine empty and only use bleach. Then when done leave the door open to dry out. Works every time.
Oct 23, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer Odors of Mildew
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our LG washer has moldy odors
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!&*%#
Jan 28, 2010 | LG WM-2277HW Front Load Washer
Moldy, mildew odor from washer
after using washer leave the door open, this lets it dry and no mold to develope.as with any wash machine, feel fry to leave the door open all the time, even slightly
Jun 20, 2009 | LG WM-2277HW Front Load Washer
The gray rubber seal on the door and opening of my fron loading washing machine has turned black with, what I suppose to be, mildew. I have scrubbed and wiped to no avail. What do you suggest?
at this point, all you can do is replace the door boot seal. but you can prevent it from happening agin by leaving the door open a little when it is not in use to allow air in the tub. if you dont, youll have another moldy boot
Apr 25, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Mold/mildew
Run a cycle with or without clothes using a 1/4 cup of beach diluted with 3/4 cup of water...max out the auto bleach dispenser with this solution. After using, leave the door open to allow the water within to evaporate. We had the same problem and this was the fix.
Apr 22, 2008 | Frigidaire GLTF2940ES Front Load Washer
LG TROMM Model WM2077CW-mildew on rubber
First and foremost you MUST use an HE detergent, HE(high efficency) is design specifically for fontloading machines.. and use little amounts of it, 2-3 tablespoons is all that is required to clean a full tub of clothing.
Jusst using less of regular detergent is not the same as using correct soap. the moldy smell and black filth when the front bellow is pulled back is actually residual detegent not being disovled in normal operation , all front loading washers are experiencing this issue, there is a new product on the market to help combat this problem and for the 1-2 months ive been reccomending no one has told me that it hasnt helpd. heres the link www.affresh.com
Apr 09, 2008 | LG WM2077CW Laundry XL Front Load...
Bad Musty Moldy Odor in Washer
Run a wash on the highest temperature, and add some vinegar into it. May do this more than one time. Be strict to wash on the higest temp some times in the month.
Good Luck
Jan 24, 2008 | Siemens WFXD8400UC Front Load Washer
Mold & Smelly in Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer door ring has mildew on it and is causing my clothes to smell moldy. What can be done to get rid of this? I've used bleach, and cleaners directly on the rubber ring, but with out success.
Unfortunately, when mold and mildew impregnate the rubber door boots on these models, it's nearly impossible to get it to go away. I would recommend replacing the door boot and follow these diligent preventive measures to keep the problem from coming back: 1. Check the area in and around the door boot after each wash for lost articles of clothing like underwear and socks. Also, clean out any lint or debris that collects under the boot. You might want to think about using a mesh garment bag for small items in the future. 2. Wipe the area periodically with a towel to get rid of the accumulation of soap deposits and dirt. This means wiping BEHIND the door boot where it meets the wash tub as well. I recommend waiting until you get ready to do a load of towels. Clean the area with a towel, then throw it directly in the wash. 3. Leave the door OPEN between washes to allow the door boot to air dry. Due to the nature of these door seals, they seal air tight and create an environment for mildew and mold to grow. 4. Run the washer with no load on the hottest cycle you have with nothing but bleach about once a week to keep bacteria to a minimum, and to flush the drain lines and pump. The door boot costs about $80 to replace, but it may be your only solution to getting rid of the smell and bacteria. Let me know if you decide to replace it. I can give you some pointers.
Jul 28, 2007 | Kenmore 44072 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
56 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
