I have a game i used to play until i die and i have a camera bag so i accidently sat on the camera bag and i found out that the disc holder was broken so the disc fell out i tried to fix it so the game i was playing is starwars elite squadron but the game wont start i push the home button went back home i can still hear the sounds and screen moving thing but the game wont work please help i cant wait until i figure out how to fix it so i can play it again
SOURCE: Directional Button and L Button Problem and another problem.
I think there might be a problem with your configuration, remove all plugin then try to restore to default setting on setting menu. and/or if your psp installed Custom firmware, the umd speed are set to fast. do this via recovery menu (hold R trigger while turn on psp). you may need to fix L button if it is stuck. you may consoder sending it back to Sony for repair.You can call SONY support at 1-800-345-7669. hope this helps.
SOURCE: My PS3 Games wont show up in the games list
Return under warranty.
the blu ray laser will have been slightly overheated and as a result will need to be replaced.
SOURCE: My PS3's hard disk file system is corrupted
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best!
P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
SOURCE: Cant reboot after red blinking light
There isn't much you can do to easily fix this problem.
Try booting the PS3 with hard drive removed.
For more tips, suggestions, etc.
Check out my guide here:
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
You will need to replace the player.
