Question about Ricoh Office Equipment & Supplies
Richo copier 1060,error code sc-501 - Ricoh Office Equipment & Supplies
What is error SE541 on Ricoh 1060
Posted on Mar 27, 2009
How can i solve error code sc:901 in richo africo 2000 copier
The mechanical counter is either unplugged or is defective.
Oct 30, 2013 | Ricoh Aficio MP 2000 Black and White...
Sc 536 error code
Ol? tudo bem! o erro funcional (SC 536) trata-se de um cooler ou do sensor de temperatura que parou de funcionar levando o sistema a parar de funcionar por medida de seguran?a, infelizmente trata-se de um daqueles problemas que s? a autorizada resolve.
Jan 14, 2013 | Ricoh Toner for Aficio 1060, 1075, 2051,...
Richo error code sc 829
I have Aficio MPC 2550 and it displays Sc 829. Is the a way to reset this code?
Apr 05, 2012 | Ricoh Aficio 1035 Copier
What is meant by error code SC 403 of RICHO AFICIO 2035E
SC 403 is a Transfer belt position sensor error
The transfer belt position sensor does
not activate even if the transfer belt
contact clutch has been switched on
twice and rotated once. Pls check if
Main motor/drive, Transfer belt contact clutch if defective, Transfer belt position sensor
if defective. or your Photo sonductor drum/PCU carriage unit does not turn or stock up or not inserted properly.
Jan 20, 2010 | Ricoh Aficio 2035 Copier
Sc code
Go to sp mode press Clear Modes 107 and press Clear Stop for four seconds. Screen will change enter to SP Modes. enter 2109-1 and execute. then enter 2109-2 and execute. That should do it.
Nov 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code sc 500
Main motor lock error
Failed to detect main motor lock signal for 7 checks in succession (total of 700ms) after main motor started to rotate, or after last lock signal was detected.
Main motor defective
Too much load on the drive mechanism
Motor driver damaged
Oct 19, 2008 | Ricoh Aficio 2015 Copier
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Err0r sc 541
Hi
fuser code your thermistor is bad
good luck
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
1,662 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
