My Dell Latitude 850 has three lit up lights on the face of the laptop that look like little LOCKS. When I try to turn onthe laptop these two or three lights light up, then the laptop turns off. I cannot get the laptop to turn on. WHen I am fortunate to have it turn on...all the lights are not lit. What is happening and HOW CAN I REMOVE THE LIT UP lock state on this laptop? It is so annoying because it seems like it loCks me out from booting up. GRRRR I feel like I have the DELL FROM HELL.
Kawika-56
  • 233 Answers
SOURCE: Frozen keyboard
Solution #1, Go to RUN type in 'msconfig'.
In startup uncheck MotiveSB.
Try to reinstall the keyboard driver. Solution #2
  Sounds like it may also be dirt or some spilled soda.
-- Had the same problem after an OJ spill. --
If you feel comfortable about removing the keyboard, disconnect all the wires and cables, then give the keyboard a thorough washing. Then let it dry overnight.
If that doesn't sound like something you want to attempt, then you will have to take it in to a computer shop.
Posted on Oct 30, 2007
mellomania
  • 121 Answers
SOURCE: Dell Latitude C640 Laptop
get to the main board of ur system there is a jumper near the battery .
change its position while power is off and get it back to its previous position. this way u will reset cmos to default.
if the computer starts hit delete to enter setup and load system defaults.save changes then exit.
ps: defected processor could be the cause
Posted on Nov 14, 2007
SOURCE: Dell Optiplex GX280 boot-up problem
Guess what? it's the CPU. Changed it with a working PC same type and unit boots up fine. Guess we learn about new problems everyday.
I think it's high time these units start telling you what component or section of the computer is faulty...too many things to diagnose.
Posted on Dec 19, 2007
Pyrhyc
  • 2028 Answers
SOURCE: Dell C400 Laptop Battery not charging
Go into the battery properties and check if the battery is charging. If it says it is, then test it, use the battery to see if it really is charging, they will sometimes give a false reading. If it's not charging, then check the power supply with an ohm meter for the proper output. If this all checks good, but the battery isn't charging, then I'm afraid you have a failed power management system on the motherboard. The power management system controls the charging along with other power related aspects of the machine. If the power management system has failed, then unfortunately, you will have to replace the motherboard in order to fix it.
Posted on Aug 12, 2008
  • 3940 Answers
SOURCE: yello power light, dell
1st remove all PCI cards, see if anything changes.  If no change\:
If the power LED is solid AMBER, replace the motherboard
If Flashing AMber, replace the power supply
Posted on Sep 10, 2008
How do I unlock the cap locks on my dell d531
If your caps lock is on, it will tell you in windows when you are typing in your password.
Jul 22, 2014 | Dell Latitude D531 Notebook
My dell latitude d630 I have pressed and held down the "FN" key and powered the laptop on. Firstly, all three status lights on ones and then stay off. What does this error light sequence mean?
the thing i LOVE about Dell is their completely transparent with their systems.
http://www.solano.edu/technology/data/D630/trouble.htm#wp1311135
Apr 18, 2013 | Dell Latitude D630 Notebook
There are three green lights that stay on by the on button
try changing the memory cards first, my cards appeared to be good but after a little warm up the laptop would freeze up with the power and bottom three leds staying on then shutting down. i changed the memory out and the problem quit. i was using cheap memory cards.
Jan 22, 2011 | Dell Latitude D510 Notebook
Dell Inspiro 6400 not starting up
If the Num lock is lit constant, and the Caps Lock and Scroll Lock keys are flashing, the system is reporting a memory error. Power off the system, remove the battery, and follow the user manual from support.dell.com to reseat the memory module(s). If the error persists, you may need to replace the memory and/or the system board of the portable.
Mar 12, 2009 | Dell Latitude D600 Notebook
Comp wont turn on
ok, all three lights is a hardware problem - this is usually related to CPU problems in the machine but can also be a sign of MB faults too - first up - remove and replace the ram - both sticks - one under the kb and the one in the bottom cavity too - if this doesnt work - i suggest either taking it in for checkup to a qualified service centre or if your feeling confident then remove the palmrest and heatsink, unlock and reseat the cpu and then try starting again
cheers
Nov 19, 2008 | Dell Latitude D610 Notebook
Dell latitude d600 doesn't turn on
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
Aug 15, 2008 | Dell Latitude D600 Notebook
Control board light on d600 want stay lit. It comes on for a few seconds then turns off.
I'm not sure I'm understanding your problem. There are three lights on the machine, power, battery and hard drive. Is the machine working, starting then shutting down, or not working? Please give me a little more info and I'll be able to help.
Jul 16, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
