Question about Dell Latitude C610/C600 Notebook
Dell Latitude cpx
I received a laptop with no info on its working condition
When I push power button, all the lights light up, as though it is going to boot. I hear a sound like the drive spinning, then most of the lights go out and the machine does not start up
Is it worth fixing?
  • 2 more comments
  • cholson Oct 15, 2008
    yes, it happens when plugged into wall
    I am not a technician, so I would not know how to check the power supply
    One light stays on, but the screen remains blank, never displays anything
  • gdayyall21 Dec 30, 2008
    I just plugged my laptop in for the 1st time in over a year. When I turned it on, it is indicating that it is charging and my screen is blank. I thought that it could be used with the power cord attached even though the battery isn't fully charged. Is this not correct, do I need to wait for a fully charged battery before it will work?
  • velut_umbra May 11, 2010
    That depends on how old is the computer. Does it happen when plugged to AC power? Have you checked if the power supply is working properly?
Well, when the power supply is plugged to the computer, there should be a light indicating that the battery is charging. One other thing, does it turn off completely (I should have asked this first) or is it just blocking? No messages on screen?
Posted on Oct 15, 2008
Dell latitude cpx. Charging Light flashes yellow then green when plugged in. When I push the power button that light and the one next to it turn green and the 2nd & 3rd light under thoseturn green...
From what you have said it sounds like your battery might be the problem. Have you connected the computer to the wall and tried to turn it on. Is the same happening then?
Mar 28, 2011 | Dell Computers & Internet
Dell Lattitude CPx
first be sure the battery is actually charging ..than second thing to take in mind is the Ram memory ..cause it is the first thing that computer sees for to boot..
i fthe lights came on ..and you still got no activity after you verify the ram memory in another computer .. the only thing that remain is the the cpu..but ..I thing in this case it is the ram memory ..or a power issue..
May 01, 2010 | Dell Latitude CPX Notebook
I have a dell Latitude cpx that wont turn on.
may be you battary is it old battary?
Oct 27, 2009 | Dell Latitude CPX Notebook
When trying to start up my dell latitude CPX nothing happens, and when I plugg up the wall charger, there is a blinking light but still no power
A blinking light normally indicates a dead battery; however, since it does not power up when power is plugged in, I would suspect that the power jack on the motherboard needs to be repaired. This would explain the lack of power and the inability to charge the battery. I replace powerjacks a lot. Good luck. -Carlos:
Jun 13, 2009 | Dell Latitude CPX Notebook
Dell Latitude
If the system still works on an external monitor and functions normally otherwise, you might be able teo replace the LCD assy for about $150.
If the system no longer works on external either, then I'd say the system is no longer viable as an item to repair as it will be cheaper to replace it then to repair it. (New laptops start at around $500)
Feb 08, 2009 | Dell Latitude CPX Notebook
My Dell latitude Cpx laptop just does not power up, just flickers
I had the same problem on my CPx. It turned out to be a bad memory module. With bad (or no) RAM, nothing is going anywhere, so it immediately shuts down. New memory, no problems.
Jan 09, 2009 | Dell Latitude CPX Notebook
It is a dell cpx lapetop. Will not start up.
change the power jack of the laptop..because the sounds like the ac power is not working in laptop..
Jan 04, 2009 | Dell Latitude CPX Notebook
Dell Latitude cpx
Try to connect and external keyboard to it
with the external monitor.
If the shortcut is in the keypads where most off the beer propably came in contact.
will now be seen if its boots up.
If it boots up with external keyboard the ptoblem is in the beer soaked keyboard.
change or clean the keyboard with isoprophanol
to dissolve moisture and beer.
This is the solution. Please vote!!!
Jul 09, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell latitude cpx will not power on
bad motherbord litte power tansformers on it getting to hot failed have to replace them or new bord
Jan 26, 2008 | Dell Latitude CpX Laptop PIII 500 Mhz...
Dell Latitude C610/C600 Notebook Logo
163 people viewed this question
Alun Cox
