Question about Sony Handycam DCR-DVD201 DVD Camcorder
Lid problems I was cheking a DVD inside the camcorder, everything was normal, I could see the images and everything. Then I wanted to change the DVD inside the camcorder, I pressed the botton to open up the lid and I could here the little bells that indicate when is ready but the lid was closed but a little up, I forced a little and without dificulty it came up but now it will not reconize when the lid is closed and the lid will not open by using the open bottom either. Because the lid is not doing his job, the camara does not work for recording, not even to finalize or to watch already recorded DVD. How much will it cost me to repair this? Who could check this for me? What shall I do?
  • 905 Answers
I fix these and we charge about $40 plus parts
the problem is a switch that is connected when closed and open when opened
so either the switch mechanism can be fixed or they will have to order you a new switch to repair it
Posted on Oct 15, 2008
  • jason Oct 16, 2008
    plz rate my help here thnx!
How to fix the problem of the screen viewing is now like a mirror effect to the objects it is seeing and the wording is viewed also like you would see it looking through a mirror. Now if you flip the view...
Panasonic Viewfinder - Mirror image:
Although I don't own a Panasonic, my Samsung and JVC camcorders have this flipped image function, so I guess most are similar in theory.
The mirror image is a function used for taking selfies, or where you want the subject to frame themselves while previewing the image on-screen.
This only affects the viewfinder screen, not the saved video or still, which remains as normal.
To correct this, you need to navigate to the 'settings' menu, exact location depending flavor of camera.
There should be an option for "self-portrait" mode or similar.
Switch this back to normal mode.
Why mirrored?
When screen is rotated 180 degrees to face subject in normal mode, they would see an inverted image, so the "selfie" function flips the graphic to compensate.
Regards,
Clive.
Dec 18, 2017 | Panasonic SDR-S150 Flash Media Camcorder
Camera won,t turn on or take a charge
If there is a firmware solution on Insignis-Products, you might be able to restore the camcorder to life that way.
However, if the unit won't turn on at all...even when a USB AC charger is used where it should function normally and completely...there is a problem with the camcorder and it may be bricked.
I hope this helps and I hope your camcorder isn't bricked.
Jul 07, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
My pc cant read the dvd of panasonic vdr-160 i want the software for
You need to FINALize the DVD to make it playable on DVD (Inside the Camcorder.) It is not a software problem.
Mar 03, 2010 | Panasonic VDR-D100 DVD Camcorder
My camcorder will not record images but it will record sounds. Please help
My Canon Elura50 did the same. It's a manufacturing defect with the CCD, (The image sensor) mount installed by Sony Corp.
Canon Service centers hounour a full repair of this problem free of charge. You just have to find one close and take it in for "CCD problem"
Incidentally Canon has about twenty or thirty cameras with this same problem. Everything works but there is no image. It's the Sony CCD mount inside Canon Cameras.
Trust me, It's 100% free repair.
Dec 18, 2008 | Canon Elura 50 Mini DV Digital Camcorder
Recording to dvd RW's from mini dvd's from panasonic camcorder
I didn't understand your question.
All dvd player can play mini dvd's. Why do you want to transfer it on a normal dvd disc???
Jan 04, 2008 | Samsung SC-DC164 DVD Camcorder
Camcorder Widescreen Recording Issue
THERE IS REALLY NOTHING YOU CAN DO as your settings conflict with each unit connected
Nov 13, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Projector gives a red background
try video signal from video or from dvd if you get the same result you have problem inside the projector and need to be fix in workshop near you.
Nov 07, 2007 | Epson EMP 52 Multimedia Projector
Sony dvd camcorder DCR-DVD201E Lid not closing
Most often, in this case, the locking relay has failed. Sony has an improved part for this. It requires a Sony qualified servicer. I have replaced them before. Good luck, magic seadog
Apr 06, 2007 | Sony Handycam DCR-DVD201 DVD Camcorder
Red vertical smears on LCD display and on playback
Your camcorder is on a list with potentially defect CCD light sensors. Sony is replacing them free of charge. Go here for the link and free mailing label: http://www.imaging-resource.com/badccds.html
Dec 13, 2006 | Sony Handycam DCR-VX2100 Mini DV Digital...
What is the Hitachi Image Engine?
The Image Engine is the combination of the DVD Camcorder lens, CCD, LSI processing circuitry, and the DVD optical laser. Put simply, the Hitachi Image Engine is what drives image capturing in the camcorder. Exclusive and proprietary Hitachi technology.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Sony Handycam DCR-DVD201 DVD Camcorder Logo
63 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
