Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
No heat in hotpoint dryer
There is no heat during the drying
  • 99 Answers
Wire burned of heater on top of washer/open circuiy heater/thermal cut out open circuit
Posted on Oct 18, 2008
My Hotpoint electric dryer no longer heat or shut down during the drying cycle. What is the possible problem?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Feb 02, 2011 | Dryers
Hotpoint nvl333gyoww gas dryer's timer stopped working and ran for an extended length of time (about a day). After looking over the dryer, i noticed that during the no heat cycle the timer would work. So...
the timer : if you use time dry the timer should always move and complete the cycle. if you use auto dry the timer uses a sensor to tell the timer to move. If your not getting any heat your sensor might not tell the timer to move.
So lets start with the no heat problem. First make sure your Vent is clear or just disconnect the vent and put a pair of womans stocking over the end to keep the dust down, This will ensure you do not have a blocked vent. ((( If you have a blocked vent on a gas dryer the safty sensor will shut off the gas valve and you will only get a little bit of heat))) Now try the dryer for small load, ((( if this solved your problem then you have a cloged vent )))
If this did not solve your problem then the coils on your gas valve in the dryer are probably bad.
Sep 02, 2010 | Hotpoint NVL333GY Gas Dryer
Hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Nov 15, 2009 | Hotpoint TDC32 Electric Dryer
No heat
Check on the back of the drum for a thermal fuse or relay. Common fault on tubledryers is no power to heating coils becuse of blown fuse or most likely the relay to heating coils is dirty. have to be cleaned about every 2/3 years depending on use.
Aug 09, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Heats take long to dry and timer won't move
The timer not moving means that the timer has gone bad. The heating problem may have to do with the timer too. You can take off the vent tube of the dryer and make sure it is not restricted (from dryer to outside) If this is plugged it will also take longer to dry your clothes.
Feb 10, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer not drying
be sure vent to outside is not blocked or hose behind dryer flattened..quick ck is to dry a load with rear hose disconnected..if problem still there suspect heating element elements are double strung if 1 coil is open (burnt into) dryer will not get hot eneough
May 19, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Heating element
this could be a partial faulty heater element, a 2 heat element could only be working on 1 element, this can overload the other one causing it to keep switching on and off at the thermostat, sometimes this can be normal but saying as you think its not hot enough, check you have the settings correct on the heater options, i have seen stranger things happen test element contacts for both circuits unplug machine first
Sep 27, 2007 | Hotpoint TDL14 Electric Dryer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
66 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
