Question about Panasonic Panafax UF-550 Plain Paper Laser Fax
Receiving blank document
We are receiving blank documents. The display is blinking. I already changed the toner. I reset it. What could it be.
  • leonor9595 Oct 15, 2008
    Panafax UF-550. We are receiving blank documents. The display is blinking. I already changed the toner. I reset it. What could it be.
  • Paul Homuth
    Paul Homuth May 11, 2010
    what happens when you do a internal print out like a journal, is it still blank, and what happens if you make a copy is that still blank
    Genius:
  • 2,120 Answers
Remove the toner cartridge and look to the left inside.
you should see 2 spring loaded loops. If one is bent down, you will get blanks.
If you want to taclke the job of straightening the loop, write back.
Posted on Oct 15, 2008
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Multiple printing
    go to the main menu and go to the printing settings.adjust it to single printing...
    May 20, 2010 | Panasonic KX-FM131 Fax
    My documents are blank after I type them
    try to check his side, what microsoft office version he is using , if he is using version 2003, you have to save the documents from your side as 2003 docs, you can do that, by pressing save as 2003 docs.
    Thanks for using Fixya
    Oct 06, 2009 | Microsoft Word 2007 Home and Student...
    Printing blank pages when receiving fax
    Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
    Jul 29, 2009 | Brother MFC-8460N All-In-One Printer
    Cartridge error -
    FRIEND THIS PRINTER IS IN RIGHT SIDE next to LEVERS OF BLUE CARTRIDGE TWO SMALL LAMPS ARE sensors, if they are dirty TONER WILL MAKE OF THIS MESSAGE.
    Jul 17, 2009 | OKI C5200n Laser Printer
    My brother fax machine - only receives black pages
    do a quick check on 2 things.
    - Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
    - check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
    Hope this will put your Brother on the track
    Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
    Changed Toner - Having Printing Problems
    try to reset the machine,
    by opening and closing the riight side door
    hope that help
    Nov 14, 2008 | Konica Minolta DiALTA Di200 Copier
    Hp 1040 random problems
    1-the line itself could be bad ( not the jack where you nplug in the wall) the cord itself could have a break in it. try changing the cord cost $1.00 at a dollar store
    2-if the memory is full after receiving a lot of faxes, check the memory when it happens
    3-if the toner is low it will store it in memory, by you checking the machine turning off and on removing toner etc... you end up resetting it for awhile.
    Dec 13, 2007 | HP 1040 Plain Paper Inkjet Fax
    Blank vertical line on pages
    open side door, should be a black assembly there with two wires, is it clean? is there any toner or hair on the wires?
    Nov 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
    Panasonic Panafax UF-550 Plain Paper Laser Fax Logo
    74 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
