Question about Dell 924 All-in-One InkJet Printer
Ink cartridge colour
Just installed new ink colour cartridge bought from dell and error 1203 appeared alignment check showed no colour
    Genius:
  • 1,605 Answers
Did you removed the tape that is on the ink cartridge contact???
try to clean the printer contacts with a coffee filter and make sure all contact on the printer is clean and in working condition.
Posted on Oct 20, 2008
The printer read Cartridte error 1203 I am reading the manuel but I do not understand how to fix it to print. I do not have it connected to the computer I just want to make copies.
Are you using Dell Series 9 ink cartridges?
Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cat ridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the lint free cloth(coffee filter work great) with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of lint free cloth(coffee filter work great on those holder contact panel.
Rick
May 30, 2011 | Dell 926 All-In-One InkJet Printer
Hi my name is Hector,on my 2.5 inch display it say cartridge erro error #1203. I checked my users guide it dosnt say anything about error numbers.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a problem and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Be sure not to leave any debris of klennex on those holder contact panel.
or try this other option:
Dell All-in-One Printer Cartridge Error 1203.
I found if you cover a copper contact on the color cartridge the error clears and the cartridge works. Looking from the contact side for the color cartridge 2nd row contact 2 from the left. I found if I use an ohm meter from 2nd to 3rd contact I measure 119 ohms. I believe that is a shorted cartridge. If you bought it New I would get it replaced. I use a SMALL square piece of Scotch tape. I believe this will work on Lexmark printers.
Jan 06, 2010 | Dell 966 All-In-One InkJet Printer
I have inserted a new color ink cartridge, but when i close the printer I get an error message that reads 'Cartridge Error, Error #1203'. I have tried two different cartridges with no success. What is...
Yes ok it will be the inks.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jan 05, 2010 | Dell 966 All-In-One InkJet Printer
Error 1203.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
regards
iversh
A very helpful rating is appreciated for answering your query...
Aug 22, 2009 | Dell 924 All-in-One InkJet Printer
Prenter 926 shows error 1203
A 1203 error usually involves some type of cartridge problem.
Did you recently change a cartridge out? If so, did you use a factory new ink cartridge by Dell?
If you did not, then that could be your problem.
Jul 15, 2009 | Dell 924 All-in-One InkJet Printer
I have a Dell Photo All-in-One printer 926 that uses Series 9 ink cartridges that recently went offline with a 1203 error message after I tried to print 20 color pages on matte finish photo paper. My...
Hope this may work for you.
or
Apr 20, 2009 | Dell 962 Photo All-In-One InkJet Printer
ERROR 1203 CARTRIDGE ALSO SHOWS UP ALIGNMENT ERROR
go to properties on the printer, maintenance, and align the cartridges from there
Oct 26, 2008 | Office Equipment & Supplies
Dell 962 Printer cartridge error 1203.
I posted this initial problem....and now, here's how I believe it works....but don't quote me!! Dell has some sort of electronic thingy on the top of the cartridge underneath the label. I pulled one off to try and refil it. Refil it I did....but the printer was having none of it saying that I was out of ink. So...that is when I bought brand new fresh cartridges from Dell. As of my initial posting - I couldn't get the new colour cartridge to work ... so emailed Dell who said it was a faulty cartridge and sent another one the next day....it worked perfectly. THEREFORE.....I summise...that once you buy a Dell printer....you are buggered - basically. You have to buy direct from them. I have gone on ebay and other shops..and bought refilled ones...buy they either don't work...or the quality is rubbish. Subsequent printers that I have bought - or will buy...will be anything other than Dell! Sorry if that doesn't sound very positive...likewise if anyone does find a way rough this.....let me know....as lumbered with this printer now till it totally breaks down....then can buy a new one (not Dell!)
Sep 28, 2008 | Dell 962 Photo All-In-One InkJet Printer
Ink cartridge errors
support.dell.com has those manuals
Aug 08, 2008 | Dell Photo 964 All-In-One InkJet Printer
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
103 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
