After replacing the Sanken IC my DmR e85h works again , no startup problems more . ;)
But the display unit of the DMR-E85H dont work - nothing is shown - only blank display unit :( - any ideas what the fix for this problem is now ?
Thanks for all ideas..
Bye
Michael
Comments:
Oct 16, 2008
- THX, really an trans?, because I cant see any shining segment of ther LCD Display unit.
Now the e85h is in the service mode , keycode 51 let all display segments and LED's on the front shine, but at my e85h the Display show nothing only the device leds are shining.
Is nobody out there they had the same problem with the DMR e85h an have fixt it allready ?
Where can I download a Service Manual for the e85h ?
Quite many possibilities. Since you replaced the IC, I'd figure you have a little understanding of electronics and ESD procedures. You now need to troubleshoot the driver for the display. Do a little research with your DVM... make sure the display is getting V. Should the unit be a uP type system, you are probably looking at the uP display driver circuitry [all in one] being bad and no way around the replacement should you desire a display. Should the unit be slightly older, you may get lucky with finding a cap or transistor problem for the driver. Moreso trans than cap.
Wish it were here.. always easier to take a peak and find the problem when it is in front of me.
El problema que tengo en mi DVD,es sencillo. Al insertar el dvd en su ranura se pone en modo self...
(More)
El problema que tengo en mi DVD,es sencillo. Al insertar el dvd en su ranura se pone en modo self check,y no hace nada de nada. No deja sacar el dvd,ni deja de leer sin ningun resultado.
it was working but you had to leave it on for a couple of hours before the power came on now ther is...
(More)
IT WAS WORKING BUT YOU HAD TO LEAVE IT ON FOR A COUPLE OF HOURS BEFORE THE POWER CAME ON NOW THER IS NOTHING AT ALL
DMR-E85H won't let me change clock. When I plug it in, the message on display is Please Wait. Then...
(More)
DMR-E85H won't let me change clock. When I plug it in, the message on display is Please Wait. Then it registers incorrect time - 2 minutes slow. Setup doesn't accept time adjustments. Can't get to Self Check Mode.
what can i do when the panasonic dmre85hs machine freezes after 2 two seconds on power up with no...
(More)
what can i do when the panasonic dmre85hs machine freezes after 2 two seconds on power up with no response to anything pressed
