Question about Canon Office Equipment & Supplies
Canon CLC900 error code E 071
The error code E 071 appears when I switch on my CLC 900
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
E071 An image leading edge signal cannot be detected within a specific time.
I beleive it has to do with your transfer unit
Posted on Oct 16, 2008
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Canon CLC 4000 Error code E013-0002
DESCRIPTION:
THE WASTE TONER LOCK DETECTION
SWITCH (SW4) HAS BEEN PRESSED FOR O.1 SECONDS OR MORE.
Solution: the waste toner is FULL.you have to get rid of that TONER.
Nov 04, 2009 | Canon CLC 4000 Copier
Canon clc 900 color copier comes up with e005
This error code relates to the fixing unit cleaning roller (web) having run out. You need to get it replaced.
Aug 27, 2009 | Canon Office Equipment & Supplies
Canon clc 900 Error E020
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Jan 13, 2009 | Canon CLC 1150 Color Copier
Canon clc 1180 error code 071-0007
k you may have several problems you may take some canned air and blow out the connectors on the tx unit and the inside frame particularly the connectors on the lower right rear frame wall .. when you pull out the tx unit you may also want to turn the two cam gears on the lower left rear frame all the way clockwise then slide unit in
Jan 10, 2009 | Canon CLC 1180 Copier
E071 0003
E-071 0003: There is an error in the rising edge timing of the signal plate detected by the C sensor.
The transfer drum isnt rotating or the machine "thinks" the drum isnt rotating. Check for mechanical interferance and check the drawer connectors for paper and debris
As for the guest with the E-803 error, thats not really the same thing at all. I guess both error codes have a "3" in it but thats about all.
E-803: During operation the CPU does not detect a 24V output for 5 sec while the transfer unit, the left door, and the delivery door are closed.
Check the aformentioned doors and switches but most likely it is the power cut relay that is faulty. The relay is located on the lower left hand side beside the main power supply. The relay contacts become pitted and burnt over time.
Apr 15, 2008 | Canon CLC 1120 Color Copier
Error E061 & 0070
grid bias at upeer limit
Dec 19, 2007 | Canon CLC 1120 Color Copier
184 people viewed this question
old marine
old marine
