Question about Motorola Mobility RAZR V3m Cellular Phone
Keypad lights some off
Some of the keypad lights have gone off permanently at the  right hand side of the pad
  • tweet-tweet Oct 16, 2008
    Thanks for your help. Now I can stop shaking it to try and get them working again!!!
    Sniper:
  • 66 Answers
Those bulbs that doesn't light up, i think it is damage. Better replace those bulbs with new one by asking professional help with a qualified cellphone technician.
Posted on Oct 16, 2008
The right hand side of the keypad not working
It's possible that your screen is dead and needs to be replaced. Try restarting your phone. If you've had it for less than a year contact your service provider for warranty support
Apr 01, 2014 | Research In Motion BlackBerry Z10
While using an USB number pad, every key strike shows an on-screen display for NumLock. How do I disable this feature?
The number lock key is located on the right side of your keyboard near the extra number keypad. it is in the top weft hand side of the number keypad. it says " Num Lock" on it and has an arrow pointing upward (usually). If you start with the last key on the right side of your keyboard it should be located four keys over.
Press it to turn on and off the number lock feature.
Mar 20, 2011 | Computers & Internet
Keypad on right side doesn't work
Try pressing your numlock (top left of the keypad) and try the numbers again. Try your keyboard in another computer -- if they still dont work, you have a hardware failure ... time for another keyboard. If it works on another computer, then I would recommend right-clicking on "My Computer" and selecting "Manage". Go into the hardware manager, and delete your keyboard, and reboot. The Windows will find your keyboard and reinstall the drivers, hopefully resetting whatever configuration was previously blocking your keypad keys.
Apr 10, 2010 | Apple M9034LL/A Keyboard
Just bought a new PD210DM opener but still have
I don't know this model. (in australia). the chamberlains here are probably the same. the 4 digit code you first put in the keypad is what you have to use. push the learn button on your operator then punch in your 4 digit No. Hold the enter button on your keypad until the light flashes on the operator.
That should code it in.
freddy51
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Toshiba Satellite A-105 doesn't have a Numeric
Hold down the FN key at the bottom left of the keyboard & press either (scr) (prt scr) or (sys rq) key witch is at the top right hand side of the keyboard, There indicated by a white square round them.
Jan 16, 2010 | Toshiba Satellite A105 Notebook
Number keys on think pad lock using openoffice.org
On Thinkpads laptops the keys on the right hand side double up as the number keypad. To switch on the Number lock key pad on - press and hold the Shift key and press the NumLk/ScrLk key, it is above the F11 key, the Num lock LED will also light up. Press these keys again to turn off the Numer Lock.
Nov 10, 2009 | IBM ThinkPad T42 Notebook
Won't run - normal light flashes
You may try removing power to D/W for a minute and reconecting. likely cause though is keypad (console). If a light above a pad stays on the pad is likely closed all the time. Normal is probably cycle most often used. you can test the keypad by removing power to D/W and accessing the control panel. remove conncter P-1 and using an ohmeter test resistance between 13 and 4 on the connecter coming from keypad. yes without very small clips or 4 steady hands it is a little tricky. in the field we use a breakout board. if you get any reading when not pushed pad is bad. you may find a manual inside the kickplate which explains the keypad sequence. it may be control but more likely keypad, even if test is inconclusive.
Jun 07, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Number keypad
You are right there are LED lights under the keypad and they aren't to hard to replace. If it was in my shop i would charge around 30.00
to fix them. In other parts of the country the may charge a little more or less though. If your phone is less than a year old it may still be under warranty i would check that first!
Jan 07, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
