Question about Telex Radio Communications
Telex model pem-77 Earset parts
I need the plastic peice that fits around the Ear for my Telex pem-77 ear set. Is there a place I can order just that peice?
Thanks,
Dave
SOURCE: Bluetooth ear set not being detected by new phone
ok, thanks.
Found the problem. As always "Read the instructions first!"
Bye
Posted on Nov 16, 2008
SOURCE: Earpiece
Ebay I bought 3 for $5.00 for my h500 from preowned phones
Posted on Jan 08, 2009
keekus
  • 83 Answers
SOURCE: CS60 ear peice with heavy static when in use
This may be caused by a few things.
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too high. First, try lowering the volume on the telephone. If you still hear distortion, adjust the volume of the headset. The master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
4. Make sure the headset has been paired to the base.
Posted on Jul 18, 2009
remaker
  • 449 Answers
SOURCE: WHERE CAN I GET THE LITTLE PLASTIC PEICE THAT GOES
eBay sells sets of them, search for "motorola h690 ear hook loop"
Posted on Feb 05, 2010
  • 16 Answers
SOURCE: I broke the plastic ear loop on my bluetooth. I
Depending on the manufacturer, they may not even sell just the loop. Go to their website and see if they list where their products are sold. Check ebay...
Posted on Mar 05, 2010
The plastic piece that fits over the ear on my explorer 232 broke in half. Can I purchase another?
Plantronics does make a replacement ear loop for the Explorer 232, the model number is 80334-01. You may want to buy a few while they are still available for that discontinued headset, see the link below for the part.
Plantronics Explorer Ear Loop 80334-01
Good luck from Headsets Direct!
Apr 19, 2011 | Plantronics Explorer 232 Bluetooth Headset
I find that my BTE open fit hearing aid solves a lot of problems but the fitting seems to creep away from the ear drum making it difficult to hear. I find I am continually pusshing the tube back to where...
There are a couple of solutions that you can try, ask your audi to fit a sport lock or change the tip he is using. If that does not work, think about investing in a set of custom made tips. A sport lock is a piece of plastic that attaches to the tubing, when you place the tip in your ear this piece of plastic is folded around the inside of your outer ear along the bowl.It aids retention of the tip.
Mar 11, 2011 | RTO 2 Siemens Pure 700 Open Fit Hearing...
One of my headphones only makes noise when pressed on with force
Sounds like the conductive cable is about to go bye-bye.
My previous in-ear started to behave like this after about a year and a half of use.At first,if I pressed or moved its body around may solved it.But about a week later,the right ear went completely silent regardless how I fussed on it.
If the symptom gets worse and worse as time goes by,you'd better look for the new earphones.
Jul 24, 2010 | Skull Candy Smokin' Buds Headphones
Constant growling noise from front drivers side. Stethoscope noisy at drivers side axle output on transaxle
If you ran this test with the wheel off and the ear peice attached to the CV area the joint is bad. I would place the ear peice on the hub and bearing area also for that may be at fault instead
Apr 26, 2010 | 1999 Toyota Corolla
Hi, I Have a w995 & the ear piece volume is low.
check around the ear piece, make sure that rubber piece is there and properly placed around the ear piece.
regards
Mar 29, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Slft earcup on QC3 broke off
They will give you a new pair for $100, even if it has been longer than a year...
http://riajournal.com/ria/index.php/2009/04/25/bose-gets-5-stars-in-my-book-for-their-qc3-headphones/
Apr 16, 2009 | Bose QuietComfort 3 Acoustic Noise...
Logitech problem
Resell It on EBAY
Sell it to me,
Third, to pair to your phone
1) Make sure the earset is charged fully overnite.
2) Turn on your bluetooth function in Phone.
3) Turn on your earset and keep pressed for about 10 or longer seconds until it becomes solid blue and not any blinking versions. This is the pairing mode.
4) Go to the blue tooth menu in phone and try to discover this ear piece.
5) Enter 0000 as passscode and the phone should get paired up.
6) If it says successfully paired , then go ahead to configure how to turn on blue tooth and automatically configure // trust // and connect to the Logitech bluetooth earset.
7) Now enjoy this ..
Beware ; When the ear peice in your pocket or hangbag, if the buttons get pressed in a way it dials out the last number called , then un-intentionally all you conversation you thought might be private or sensitive in nature will be heard by the the person answering your phone , or worse even it goes to their voice mail,, all your scoop is recorded by the modern phone voice mails...
So Be care full and save some embrassment or OOPS , got me with pants down moment...
Mar 17, 2009 | Logitech Traveller (980399-0403) Wireless...
ok, thanks.
Bye
Nov 16, 2008 | Jabra Bluetooth Headset with Adjustable...
Radio Communications Logo
78 people viewed this question
Top Telex Radio Communications Experts
Mike Charette
Andrew Taylor
Andrew Taylor
Are you a Telex Radio Communication Expert? Answer questions, earn points and help others
