Question about Philips GOGEAR SA6045 MP3 Player
GoGear SA5245BT Will not do nothing!!
When you turn it on or plug into computer all it shows is GoGear and will not do anything else. It was working fine but then just started doing this. Please help I've had it for about 6 months and used it like once.
No reconoce el reproductor en mi pc
pero se lo detecta como usb
Posted on Oct 15, 2008
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My volume button broke
1 Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
2 Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
3 Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Apr 17, 2012 | Philips GoGear ViBE Digital Media Player
I was charging my media player and now it is stuck in charge mode?
Hi,Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Good luck.
Mar 11, 2011 | Philips GoGear ViBE Digital Media Player
My philips go gear ipod got hang.
The SA5245BT bought in India, is a consumer electronics product. It has a warranty of 12 months.
When the player freezes, try to resolve this problem with the trouble shooting from the support page of the Indian site (in English) for the SA5245BT/97:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA5245BT/97&slg=en&scy=IN
I assume you already tried a reset: gently press the small reset button with the narrow point of a paperclip for example.
When after the reset the player won't work as it should, you could go through the "Troubleshoot your player" link:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?session=20100802062752_94.214.10.98&scy=IN&ctn=SA5245BT/97&slg=ENG&dct=DTI&did=IN
If the operation/keypad on the player keeps freezing, mostly during the power up, the only way to restore the player is to use the Device Manager Repair Wizard.
Start from:
Repair/Update
How can I repair my player using Device Manager
select your operating system XP, Vista or W7
and follow the steps
Aug 02, 2010 | Philips GOGEAR SA6045 MP3 Player
I CAN,T VIDEO DOWNLOAD IN MY GOGEAR SA5245BT/97 PLS HELP HU
Hello''
I do not exactly the understand what you are asking. Can you please Specify?
Kind regards
Andrea
Jul 28, 2010 | Philips GoGear SA5245/37 Digital Media...
I bought a Gogear 2gb philips SA018 mp3 player i dont know how to start it and download anything theres no instructions and its not showing anything. how do i charge it?
I have problems with the Philips SA018 4gb MP3 player. While it is connected to the computer the it shows green once it is disconnected it goes red and nothing works.The battery should be fully charged as it shows green,but as I have said once it is disconnect it turns red and that's it...there is no joy.I wonder is there a problem with the battery...? Has anyone else had this kind of issue?
May 21, 2010 | Philips GoGear SA178 MP3 Player
It just says gogear on the screen and it will not show anything else. i can't turn it off it seems as if none of the bottons are working. the battery lookes to be charging then this Gogear will just come...
It just says gogear on the screen and it will not show anything else. i can't turn it off it seems as if none of the bottons are working. the battery lookes to be charging then this Gogear will just come back on till the battery runs out. what can i do.
Sep 15, 2009 | Philips GoGear HDD1830 MP3 Player
Blnk screen
my mp3 player is just showing a blank white screen. it wont turn on, wont turn off, my computer wont recognize it, nothing. whats going on and how can i fix it? thanx. anything will help at this point.
thanks dw dreamingmusic06@yahoo.com
Jun 01, 2008 | Philips GoGear HDD6330 MP3 Player
Shows "this device cannot start" when i plug in the device
My advice to you would be to go get a new media player that isn't a phillips product. The headache that the hdd 1630 caused me almost made me go insane. I spent countless hours on the phone with tech support. They even sent me a new 1630 that I had for 2 months when the same problems happened again.
This thing is nothing but a expensive paper weight.
Mar 28, 2008 | Philips HDD1630 MP3 Player
FROZEN!!
First, try resetting the GoGear. Make sure the GoGear is on, if possible. Use a small paperclip or other device and press it into the reset hole. If the reset doesn't work, then:
Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
-Tha Mp3 Doctor
Jan 19, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
142 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
