Question about BenQ MP610 Multimedia Projector
My projector projects a yellow image on the screen.
The picture displayed from the projector is yellow.
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
Can't get my Viewsonic projector to project an image AND show image on my laptop screen
Hold the FN+CRT/LCD or (it could be an icon/image of a screen) simultanesouly and then keep press the CRT/LCD key it should eventually get around to displaying an image on just the projector or projector and laptop screen
Jun 08, 2010 | ViewSonic PJ500 Multimedia Projector
Projector says lamp failure and picture has turned Yellow
replace the unit,it sounds like its old,has been used a lot,and needs a complete replacement.
May 06, 2010 | Hitachi EDX-3280 LCD Projector
IXD 420U projector takes a long time to project and has pink ima
If possible, try to replace the VGA cable between the projector and the computer. A bent or broken pin, or a damaged wire, can prevent the blue or green (or both) portions of the picture from being displayed. The result is a reddish/pinkish picture.
As for the long time to project an image, this could be an extended warm-up time. How old is the bulb in the projector? Does the projector have an option to display the hours used and/or remaining on the bulb? Bulbs do have a finite life, and when they near the end of their service life, they can become more difficult to start.
Hope this helps!
Feb 22, 2010 | Office Equipment & Supplies
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
May 21, 2009 | Sharp XG-E3500 Multimedia Projector
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
Screen adjustment
Adjust the screen area of the computer’s display settings to match the projector’s native resolution. Refer to your projector documentation for the optimum or native-resolution setting for your projector model. If you can't find this information or are uncertain, most projectors support a maximum of 800 x 600 pixels.
• With certain laptops, you might need to disable the laptop display to obtain the best image, especially when the native resolution of the laptop exceeds the native resolution of the projector.
• Font smoothing will automatically generate a cleaner font outline, both on your laptop and on the projector. To apply font smoothing, do the following:
1.
In Control Panel, open Display.
2.
On the Appearance tab, click the Effects button.
3.
In the Effects dialog box, select the Use the following method to smooth edges of screen fonts check box, and then select Standard or ClearType in the list.
If the projected image is dimmer than it was on the laptop, check your projector documentation for information regarding lamp timers. If the lamp life has expired, replace the lamp for maximum brightness.
If the projected image is not rectangular, try one or both of the following:
• Make sure that the projector is perpendicular to the viewing screen.
• Raise or lower the projector.
If the projected image displays vertical lines, "bleeding," or spots, try one or more of the following:
• Adjust the brightness of the image.
• Check the projector lens to see whether it needs cleaning.
• Adjust the sync and tracking on the projector.
Sep 09, 2008 | Panasonic Videoprojector PT-LM1E...
YELLOW SPOT ON SCREEN
There may be a dust fleck on one of the LCD screens inside your projector. I had a similar problem and managed to clean it. But it requires you to dissassemble the entire projector !!!. If you are not technical, don't do this yourself. !!!
Feb 16, 2008 | Sony VPL CS5 Multimedia Projector
Yellow area in the projected image
Hello Media Man,
Looks like your projector has done it. Thats acommon trouble to ageing polirising lens, usually the blue. less blue, the green and red make up the yellowish image on the screen. The blue is bombarded with tremendous heat from the lamp and it fade and wash out. If its free, its worth replacing. Get quote for the poliriser; 2 pieces each color.
Good Luck.
Sep 28, 2007 | Mitsubishi ColorView XL30U Multimedia...
BenQ MP610 Multimedia Projector Logo
957 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
