Anyone come across this problem beforethis machine had been pretty much sat in a cupboard since it was bought in 2002. Last week my missus discovers it, brings it home and we start using it without a problem.
Last night it slowed right down to a crawl and wouldn't even paint the screen properly so we pulled the PSU and battery and now it won't power up - pressing the power button makes all lights apart from the battery light for about 5 seconds but then they go off again.
If I hold the windows key down when switching on it spins up the hard drive and cooling fan but that's all. I have to pull the battery again to make it go off.
-   I have a Dell C610. If I hold the windows key down when switching on it spins up the harddrive and cooling fan but that's all. I have to pull the battery againto make it go off.
I tried more memory and I pulled the battery and changed power adapters.
Your battery is bad replace it. Been sitting to long and has gone bad.
Was this helpful?
Yes
No
Solution #2
posted on Sep 08, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i gotta hold down the power button for 20-30 seconds to start mine cold....
Solution #3
posted on May 28, 2006
Joey2 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I had this exact same issue with the same computer (dell c600). The instructions provided (reseat the memory) worked. Problem solved. However, it took 2 or three tries to get any result.
Thanks,
CW
Chris Willis ModelGolf LLC cpw(AT)modelgolf.com
Was this helpful?
Yes
No
Solution #4
Riddle - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
On Sat, 01 May 2004 13:56:23 GMT, "Christopher Muto"
Hey Christopher,
Calm down a bit eh? Maybe it's my fault for not explaining my background, but many years experience has taught me that if I ask a group a question and tell people I'm field service I invariably get either no response or remarks like 'why are you asking here when clearly you should know'
Maybe you also missed the smileys in my last message?
Thanks for replying anyhow.
-- cheers,
witchy/binarydinosaurs
Was this helpful?
Yes
No
Solution #5
Melissa - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
prehaps you need a lesson in how to add someone to a kill file... let us know if you need some help.
Was this helpful?
Yes
No
Solution #6
Jimmy NY - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
now if you would just do this more often!
Was this helpful?
Yes
No
Solution #7
Bray - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
sorry to have bothered you . won't do it again.
Was this helpful?
Yes
No
Solution #8
Bouncy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
On Fri, 30 Apr 2004 12:21:41 GMT, "Christopher Muto"
one 3.3V PC133 dimm is no more worse for a machine than an identically specced component from another machine. I'm a fully trained digital/compaq/hp field service tech so I know what I'm doing, but if I come up against an unfamiliar bit of kit I'll ask questions first before wading in and pulling things to bits :)
In this case we have a dead CPU, which is a bit annoying as I won't be able to get another one till tuesday
-- cheers,
Was this helpful?
Yes
No
Solution #9
Cornish - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
might be good for her machine and not so good for yours... perhaps i did not make that point clear.
Was this helpful?
Yes
No
Solution #10
Mini Me - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
On Fri, 30 Apr 2004 11:38:30 GMT, "Christopher Muto"
I nicked the memory from the Missus' laptop where it's working quite happily :) I'm now about to do a CPU swap and see where that gets me.
-- cheers,
Was this helpful?
Yes
No
Solution #11
Rank: Apprentice
Rating: 0%, 0 votes
i wonder how you determine the replacement 'known good' memory module to be good. i have seen memory issues with inspiron 4000/4100 and latitude c600/610 where they demonstrate the symptom that you describe. oddly, these machines with incompatible memory installed can boot with the ac adapter in use but not when on battery only. seems likely that is your problem. of course the system could have just died, it happens... but reseating everything is a good idea (hard disk, processor, all removable drives, battery), and keeping only the necessary, minimum number of components connected also helps in troubleshooting. good luck.
Was this helpful?
Yes
No
Solution #12
kcw573 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I wondered about that but surely it wouldn't prevent the machine powering up?
-- cheers,
Was this helpful?
Yes
No
Solution #13
Cato - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
On Thu, 29 Apr 2004 23:14:58 GMT, "Christopher Muto"
Ta for that Christopher, but I'd already tried that and swapped the DIMM out for a known good one. It's interesting to note that the machine behaves the same whether there's a DIMM in there or not.
Later today I'm going to pull the CPU and put it in a good machine just to see what happens
-- cheers,
Was this helpful?
Yes
No
Solution #14
Perkins - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
most likely cure: reseat the memory #
Was this helpful?
Yes
No
Solution #15
Beresford - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Worn out/emty/defective C-mos battery ?
Was this helpful?
Yes
No
Popular Solutions for Dell Latitude C610 PC Notebook
HP Compaq NX9420 Laptop Power supply shorted out replaced new Power supply purchased but Laptop will...
(More)
HP Compaq NX9420 Laptop Power supply shorted out replaced new Power supply purchased but Laptop will not power up suspect mother board shorted out also. Any suggestions
I have latitude dell c610, when I power it on it tell me it can see the hard drive and that the cd...
(More)
I have latitude dell c610, when I power it on it tell me it can see the hard drive and that the cd rom is not properly fit it whilst its properly fit in. now when i take out the cd rom it tell me that it cant see the hard drive
When I attempt to boot up my Compaq laptop it says or to resume. But when I hit either of these keys...
(More)
When I attempt to boot up my Compaq laptop it says or to resume. But when I hit either of these keys nothing happens.
