Question about Hotpoint TDC32 Electric Dryer
Hotpoint TDC62 Hello, I need help! My Hotpoint TDC62 dose not turn on,there seems to be no power to the unit at all. I have checked the fuse and tested it on another item to confirm it works and dose. I have also checked the filter,water,and ensured the door was closed correctly but still no life at all (no lights) dead. The strange thing is, this happened six months ago and as we where just going a way for a few days, we did nothing to it until we returned, before calling someone out by chance we tuned it on and worked fine up til now...very strange. any help would be great.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Your dryer is probably worn out in the area of the front slide assy / bearing. They all do it. the drum is binding and stopping the motor sometimes...can be noisy too...
Posted on Nov 04, 2008
On my one it was the door switch at the top of the door in the centre there is a white little nob sticking out see where that goes into the machine and gently put a screw driver and push there is a switch in there which plays up
Posted on Oct 27, 2012
Hotpoint TDC62 drying clothes ok but not cooling down at end of cycle
I would check the cycling thermostat, the hi limit, the moister sensor, control board lastly
Mar 21, 2015 | Hotpoint Dryers
Don't seem to get heat for the dryer. checked my fuses. all seens to be ok.
hello check the heat sensors there may 2 of them you will need a multimeter to test them if 1 is faulty change both of them. these will be located at the back of the dryer also check the element as well and make it's not the vent is not blocked hope it helps
regards
shaun
Mar 13, 2011 | Hotpoint NVLR333EE Dryer
Hotpoint Aquarius TCM570 - This unit is just over 12mths old!!! The heat function has ceased to work, it still spins etc but there is no heat. I've read on a previous posting relating to the same tumble...
Always disconnect power while working on unit....to easy, disconnect the two wires from the fuse, take black electrical tape and tape them together, test dryer if it works then disconnect taped wires and buy fuse install new fuse. Here is a website that should help, Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 27, 2010 | Hotpoint Dryers
I Need to change the belt on a hotpoint TDC62 dryer, but I cannot see how to remove the front panel
first take off the top then remove the back most tumble dryers dont have a removable front pannel
Nov 27, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC62 condenser dryer does not heat up Hotpoint TDC62 drying light does not come on. It flashes briefly when you press the start button but then goes straight off. Why? If you tap the machine the...
Most likely, the orange relay switch (Schrack RT314024) on the circuit board of the dryness module (blue colour) is faulty. RS electrics and Farnell has it. Costs £2.50. Mine had the same problem and changing it sorted it. I also replaced all the four small electrolyte capacitors on the circuit board (which you don't have to replace - I am a bit fussy with capacitors).
Your thermostats and heating elements are good (don't change these).
Jan 17, 2009 | Hotpoint TDC32 Electric Dryer
I have just replaced a broken heating element on a Hotpoint TDC62, put all the covers back on, and tried to switch it on - but it won't work. I've changed the fuse in the plug, but still nothing. I have a...
There is no circuit breaker in this dryer as such.
Establish that you have got power to the m/c, if you have, then could be faulty door switch, or you may have inadvertantly pulled a wire off somswhere.
Try the dryer in another socket and make sure you know that the fuse is a good one.
Dec 10, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC62 condenser dryer does not heat up My hotpoint tdc62 does not heat up. I had it for approx. 5 yrs, have changed the thermostats(years) before,but have come up with a new (recent)problem. when...
I think the problem still lies with the thermal switches, they have a tendancy to corrode where the spade connector attaches to the body (see pic)
Mar 11, 2008 | Dryers
Hotpoint Utima Logic Sensing Condenser TDC62
lewensc...this sounds like a classic timer issue. Before replacing it, first turn off your mains breakers and then back on. Check all wiring from the breaker panel to the unit. If okay, then have a quick look at the items in the dryer and test them using a multi tester. If nothing is amiss, replace the timer.
Dec 17, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
252 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
