Question about Sony Cyber-shot DSC-W30 Digital Camera
DSC W30 digital camera, wont power up!
The battery is fully charged, and i can get the Camera to switch on!
Any Idea's?
  • 1 more comment
  • nonomilca Oct 22, 2008
    i also have the same problem.please notify me if there is a possible solutions ok.thanks!!
  • SERVICE911 Nov 12, 2008
    I HAVE THE SAME PROBLEM
  • Derek Madge Dec 26, 2008
    I have been very happy with the camera though I've sued it only a half dozen times. It's jsut out of warranty now of course. I went insert the recharged battery, ready for Christmas, and it was a bit difficult to fit in but I managed. Later, when I tried to turn it on, the lens extended as normal and then it jsut shut down! Checking inside I found the kittle blue push button that should eject the battery had broken off and been lodged inside the battery compartment. Carefully removed the platic but can't get the darn thing to turn on! Missed Christmas and will miss photos of my first grandchild's first Christmas with me! GRR! I can't locate any interlocking switch and have run out of ideas.Does anyone know about interlocks or other solution? I'm ready to go back to film.
    Scholar:
  • 33 Answers
This is embarrassing because I usually know what I'm doing with this stuff! I don't know why, but all it turned out to be for me anyway, is that the battery had lost its charge very quickly. I still don't know why but it's been fine since! I still ahve to cover the battery compartment door with tape but other than that, it's working as expected. Of course, I figured that out after I'd run out and bought a substitute!
Posted on Feb 19, 2009
  • Derek Madge Feb 08, 2010
    I coincidentally ran into the same symptom with a different cause, in someone else's camera. The lens went partway out and stopped. Sometimes it withdrew and shut down. I determined that there was a tiny bit of grit on the lens barrel. A few shakes forward, with camera very firmly in hand, eventually cleared the debris and it worked fine after that.
2 Suggested Answers
  • 36 Answers
SOURCE: Sony Cyber-shot DSC-W30 Digital Camera
If you want to reset DSC-W30, press Menu and go to Initialize, select it and press OK
Camera will be RESET and go to factory default settings.
Posted on Feb 10, 2009
When I turn the camera on it says access , the lens goes in and out then I get a beep and message reads turn the power off and on again. I've done this over and over again and it still won't work. ...
One thing to test before going to repair, make sure you are using a fully charged and correct battery for your camera.
If so, the camera will need repair. This is a common problem and can be fixed. Teleplan Camera Repair does a great job and their blog is also very informative.
Repair: http://www.teleplancamerarepair.com/Sony_Cyber-shot_DSC-W30
Aug 04, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
When i turn my sony dsc w30 on....it says turn power of then on..
Please make sure that the battery is fully charged and there are no dust particles near the lens which stops retracting. Check if you are able to access the Menu. If yes, then, please Initialize the camera under Main settings 1 Menu. If you are not able to access the menu, you may have to power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Dsc p73 wont switch on when in green camera mode. Tone is short, swiches on in photo preview only with normal tone battery is fully charged.
I'm sorry that the camera is not turning ON. Please make sure that the battery is fully charged.
Please reset the camera by pressing the reset button located near the DC IN jack. if the issue still persists, please power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 26, 2009 | Sony Cameras
Camera won't turn on
There was a POWER button.Please press the button.The button will show GREEN.
Dec 14, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera dsc w30 digital camera reset
Dec 01, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
My less than 2 year old sony dsc-w100 keeps powering off and on
my only idea would be that the power button is glitching out...anything in the manual about this?
Jan 22, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Dark LCD screen
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jan 11, 2008 | Pentax Optio W30 Digital Camera
Bad battery
Your Brother Killed the Battery so Your brother goes and buys you another, And this time use the appropriate charger routines as outlined in the manual
Aug 27, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Camera doe not switch on
Hello, please replace/charge the batteries. Regards, Arpi
Apr 01, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera Logo
161 people viewed this question
Top Sony Cameras Experts
Larry Spears
Larry Spears
Are you a Sony Camera Expert? Answer questions, earn points and help others
