Question about Garden
How to determine chain size
I have an eager ****** 16" chain saw. How do i determine which chain is correct replacement. they have 52 link, 54 link ...etc.
  • cyberbrown Nov 16, 2008
    Where do I find Ryobi replacement chain # 901431001 ? 18" blade
  • Anonymous Jan 15, 2009
    I have a Husqvarna model 350 chain saw and have a hard time trying to sharpen the chain.I am unsure which size file I should be using 7/32 or 3/16.
    Any help is appreciated.
    Mike
    President:
  • 1,450 Answers
The 16" has 54 links
this should be part number
McCULLOCH16" REPLACEMENT CHAINSAW CHAIN 91V-54
Posted on Oct 15, 2008
How many drive links does a McCulloch MCC1635A 16-Inch 35cc 2-Cycle Gas-Powered Chain Saw bar have ?
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Sep 02, 2014 | McCulloch MCC1635A 16-Inch 35cc 2-Cycle...
Exploded parts view of mculloch 2014 eager beaver
Refer to your service manual.
Contact us
User manuals
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Nov 07, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel line diameter mcculloch trimmer eager beaver 2
According to Randy Duncan Ebay site(Randy's Engine Repair) the fuel line is 3/32" inner diameter and 3/16" outer diameter for the non-primer bulb side of things for a McCulloch chain saw. It is a common size, apparently, but is not listed in the User manual as such.
Apr 30, 2012 | Garden
What is the correct fuel/oil mixture for an older Eager ****** 16 inch chain saw?
It really depends on the model number of your Eager Beav er unit. Anything within the last 6 years is 50 to 1 older models can be anywhere from 25 to 1, to 32 - 1 up to 40 - 1. t all depends on the model number.
The usual fuel mixture is 40 - 1 or 3.2 oz. per gallon.
Your chain saw would have to be pre-1995 to use a mixture greater than 40-1. If your chain saw is other than that then use a 32 - 1 ratio. 4.oz per gal.
This is a great fuel mixture calculator:
http://www.csgnetwork.com/oilfuelcalc.html
If you know your model number you can use this page to get an owners / operators manual:
http://www.mccullochpower.com/node7877.aspx
Jun 16, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need model number for the chain for a McCOLLOUGH EM14ES chain saw. Thank you.
Any good chainsaw shop will make a chain up for you, most hobby machines run a 3/8 050 low profile chain such as 91s or 91sg, the lenght is denoted by the drive link count, 52 54 56 etc
May 31, 2011 | McCulloch Garden
What is the tread size of idle screw.for Eager ****** Mc Culloch chain saw and where I could find one.
They normally us an m5 or m6 screw, any good chainsaw shop shpuld be able to source one for you.
May 14, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What size file should I use ona Husqvarna 137 chain saw?
The question you ask is dependent on the chain in use not the saw that drives it. To determine what chain is installed we must see the chain. A local seller/mechanic should be willing to answer your question. Lowes will not know!!!
Excerpt from "How To Sharpen a Chain Saw" here follows:
http://www.grounds-mag.com/mag/grounds_maintenance_sharpen_chain_saw_2/
Use the right tools
If you're holding it correctly, a proper-diameter round file simultaneously restores the three different angles of a saw-chain cutter. Different-sized chains and different cutter styles call for different file diameters. It is vital to use the right size file.
In general, 1/4- and 3/8-inch-pitch, low-profile chains call for a 5/32-inch file; 0.325-inch-pitch chains require a 3/16-inch file; and standard 3/8-inch-pitch and 0.404-inch-pitch chains demand a 7/32-inch file. Beware, however, because many exceptions exist. For example, some brands of standard 3/8-inch-pitch chain require a 3/16-inch or 4.5-mm file. Check your chain-saw owner's manual or saw-chain instruction sheet to determine the correct file diameter. If you're not sure, ask your dealer. He also may have literature showing the proper filing angles and special procedures for your chain.
Getting the angles exactly right is not as important as removing all damage from the side plate and top plate and making sure the critical top corner is really sharp. However, for good results, you must consistently hold the file at the correct height and orientation within each cutter. This is difficult to do without some type of file guide.
Like most tools, simpler is better when it comes to file guides. The best guides are plates that drop over the chain. These keep the file at the right height and attitude and have witness marks to show proper top-plate angle alignment. The best thing about this type of guide is that you can see what you're doing. Guide plates that clamp to the file and rest on the cutter top plate also are good, but they tend to obscure your view of the cutter. Whichever guide you select, make sure you get the right model for your chain.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 15, 2010 | Husqvarna Garden
Where do I find a replacement chain for my McCulloch Eager ****** 2318av chain saw (model # 600038-12)?
Your friendly neighborhood chainsaw shop can fabricate one in about 5 minutes. Take your existing chain for use as pattern.
McCulloch.com
http://www.ordertree.com/modelinfo/MCC/11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318/139.11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318.1.59.1.html
If original 18" bar.
part number(pn) MCC 21927533
Oregon Bar & Chain Selector (again original 18" bar)
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Your saw with 18" bar returns
Oregon pn 91VG060G.
This can be easily crossed to other manufacturers chain. You might consider a more aggressive chain (dependent on your level of expertise). HTH
Lou
Jan 20, 2010 | McCulloch Garden
Interchange smaller bar & chain for existing chain saw
Yes you can(better for the engine).For14" the part number is 52 and for 16" is 60.
savumihai71
Oct 13, 2008 | Garden
Garden Logo
1,375 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
