Question about Epson Stylus Photo R220 InkJet Printer
R220 printer will not take cd/dvd tray
The cd/dvd tray goes in but hten comes right out and therefore will not print - i have bought a new tray but it still doesnty work
  • JErwin666 Oct 20, 2008
    I replaced my tray because the mylar strip was bad. the new one has a few projections instead. It goes clear back then ejects.
  • Anonymous May 09, 2009
    Come on "Guest", we're not idiots. If you're going to offer a solution, READ the problem post FIRST. "kathrynj87" said it goes in but comes right out. Sheesh...!
I know this sounds daft but make sure that it's not hitting the wall on the back of the printer
Posted on Oct 19, 2008
Printing to adhesive CD labels
you need software like Nero to print on cds
Nov 05, 2013 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I'm having trouble printing on cds (they won't load) with my epson stylus photo r220. I've followed the directions, lined the tray up properly. Set the settings for cd/dvd. Tried old and new software.
Depends how long you have had your printer, epson are well know for the rollers that takes the paper in getting worn, and so does the cd/dvd tray, eventually you have to push the tray in by hand to get the thing started, somtimes changing the disk tray helps, if youve got a spare one,
Dec 21, 2009 | Epson Stylus Photo R220 InkJet Printer
After printing a CD lable, I get a paper jam or CD/DVD tray jam, when the tray is already removed for the next CD. I must re power the printer to print one or two CD
Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I read from other comments that the markers on the tray must be clean. As I already printed several hundred CD/DVD the leading marker on the tray was badly marked. Tried to clean it with an eraser but I got very bad result. I tough I could paint it with some white paint but instead I use micro correction tape and white the marker. I had it working for 10 CD in a row, not bad for a cheap patch.
Where can I order a new CD/DVD tray
Oct 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson r220 dvd tray
This happened to me when there wasn't enough space behind the printer for the tray to stick out as far as it needs to.  I just moved the printer and it worked.
Dec 29, 2008 | Epson Stylus Photo R220 InkJet Printer
R220 printing on cd tray instead of disk
double check how you are inserting the tray into the printer. It should be with the cd in the holder, facing upwards and cd in first.
Gremlin11
Dec 10, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson 220 not printing cd labels anymore
Clean the white areas on the tray with a light solvent cleaner like windolene/windex liquid. Also try giving the tray a helping hand as it is started to be fed into the printer
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Error message "tray set up not correct"
I had the same problem. It's easy to fix.
Simply pull your printer away from the wall about 8". The tray needs to stick out from the back of your printer when it loads. If it hits the wall, it will not work properly and eject. Just try moving your printer forward enough so the tray can stick out from the back and you'll be fine.
RJP
Dec 17, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
291 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
