Question about Samsung CLP-300N Laser Printer
Apple Time capsule
The printer works perfectly when connected directly to my MacBook Pro via USb or wireless vis a Netgear router. When I try to connect through Time Capsule, it recognizes the printer but will not print. Many hours on the phone with Apple support and no resolution. I returned the Time Capsule and reverted to the original router, works perfectly again. I would like to use the Time Capsule at some time...I love wireless automatic back-up's...Any one else have this problem?
  • Anonymous Feb 02, 2009
    Exactly the same problem with the Samsung CLP-300 until we've installed Mac OS 10.5 m...
SOURCE: ML4600 only print 2 pages
It could be losing connection to the printer when there is too much information to print.
If the cable the information needs to travel through is too long or the distance to the printer is too far - information is "lost" due to the stability of the connection.  The longer the information needs to travel the more unreliable and unstable it becomes.
Have you tried from a different computer to print the document?
Posted on Jun 19, 2008
smartr10U
  • 1305 Answers
SOURCE: Can't print from MacBook, through Time Capsule, to Lexmark x5470
turn on the printer sharing via the system preference panel on the computer that is on the system via usb.
Then on your wifi computer look for shared printers and you'll see your printer in the list under the host computer name... use that setting and it should fire up for you!
let me know how it goes...
Posted on May 28, 2009
SOURCE: Samsung ML-2510 Printer will not work with Macbook Pro - OS X
try to use the Generic drivers and not the Samsung ML driver for your model. In the drivers list type in GEN and it'll show up.
Posted on Apr 27, 2010
mcavinee
  • 236 Answers
SOURCE: samsung clx3175fn printer was connected to a
Go into the control panel and select add printer. Follow the instructions and the printer should be recognized.
Posted on Mar 19, 2011
Ezrahite
  • 2632 Answers
SOURCE: Trying to do a "wireless
Welcome to Fixya. Can you please try to download and install the driver that is compatible with you macbook on the link below. It also includes user manual incase you need assistance on configuring the printer. Please click on the Drivers tab for drivers and Manual Tab for user manual
Samsunng CLX-3160 AOI Support
If you have questions please let me know. Thanks for using Fixya
Posted on Apr 17, 2011
HP Envy 5530 first some time ago stopped copying and scanning busy it said. Yesterday started with everything flashing showing: Code# C2EBA341 I uninstalled the printer.
why not reload the software from HP.
that be like first
no OS stated,, cept MAC.
I had tried, so did it down load, fully and the fully install, you said only TRIED !
ah wireless, that is hard
does thie printer work , to other PC< or direct.>>>>??
lean to diagnose, we start simple the work to hard, (wifi)
no one here can do that for you,its you deal.
this printer does 3 ways
wireless
wireless direct
wired ethernet never
usb
so does USB work , on your pc or others/. then the printer is ok
and you need wifi training, (not easy most times)
you never once side wifi direct or to wifi router (indirect)
the router, is best. so what router is it.???
did you set up a reserved, IP address, for your printer?
let me tell you this is always best, then you write doen that IP
on paper stick it to the side of the printer, so you know where to connect.
did you do the steps for manually wifi setup to the router in the manual.>
the HP software will attempt to find the rounter, and find and free
DHCP IP address, and can do so, but many times this fails.
ON my fancy router log in and see it. in the IP connected page.
if missing then the HP is not connected, telling which end is bad side
printer
or the MAC end. APPLE END.
IF You knew all that you can even ping the printer. from any PC on the LAN
why not use USB first. or all the time.
if sharing the printer is necessary ,start with USB
then get the printer on its own reserved IP, ending the hardships.
then sharing is next.
May 28, 2017 | HP Computers & Internet
Backup macbook pro harddrive
you can use the OSX built in "Time Machine" and connect an external HD or even better a Time Capsule WiFi station from Apple.
Can use Apple Time Machine to restore to new MacBook Ask Dave Taylor backup-macbook-pro-harddrive-abadwnk1mj4brvvpzp1wcyyy-4-0.jpg AirPort Time Capsule 2TB
Oct 17, 2013 | Apple MacBook Pro Notebook
Need to scan from hp 4345mfp to macbook pro
This site shows that as of October 2017, the 4345mfp doesn't have software available to scan from the printer. You would think that a file physically sent to a Mac from the device should be seen, but apparently that isn't the case.
https://support.apple.com/en-us/HT201465
"You can share your USB connected scanner with other Macs on your home network." So you might go that route; connect to the Mac and share the printer to other devices.
https://support.apple.com/en-us/HT204790
Feb 20, 2018 | Office Equipment & Supplies
Not able to connect the extender to my apple time capsule? no wps button. can i use this extender?
Hi, yes you will be able to use the Netgear range extender with the Apple Time Capsule, provided you configure the Time Capsule's wireless settings based from the wireless security you have setup on the Netgear router or extender. No need for WPS button. Just treat the time capsule just like another wireless laptop.
For instructions in setting up wireless settings of Time Capsule click on this link -->> http://www.apple.com/timecapsule/wireless.html
Hope this helps. Glad to be of service.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
How do i connect to apples time machine?
You can manually configure the time machine to accept wireless signal from the router or extender. If you setup WEP on the router or extender, make sure you setup WEP on the time machine as well.
Hope this works for you.
Connected Canon MP610 to Apple Time capsule via USB. My Macbook pro prints wirelessly perfectly, as does my sons Vista Laptop, however my daughters vista laptop and my wifes XP laptop print black fine, but...
Hi richardhaley,
Isee that you are having issues with your Canon MP610 printer.
You mentioned that your printer is connected to an Apple Time capsule via USB and that it works fin on your Macbook and on your sons Vista Laptop but prints the colored shifted to the right on your daughter's Vista and wife's XP Laptop and this is connected via USB.
If I may ask have you tried printing wireless using your daughters Vista Laptop and you wife's XP Laptop to see if the colors are still gonna shifted to the right.
Also you mentioned the drive that the driver you are using is from bonjour but still you have the same problem.
Here is a link where you can download drivers specific for the versions of windows your daughter's Vista and your wife's XP would have, you will need to select exactly the OS operating system for the driver that you need also there is a software for each Operating system as well maybe you can download that as well for both system for you to be able to recalibrate the printer from the 2 machines.
I hope that this will help.
Thank you for choosing Fixya,
mvincentc
Jun 06, 2011 | Canon MP610 Photo All-In-One Printer
Hi. I am running RoadRunner as my internet provider on this modem. It will connected wired with my Ethernet cable to my MacBook Pro 15, but I am suddenly unable to connect wirelessly using my Apple Time...
Welcome to Fixya
You dont need a CD or driver to connect to time capsule. All you need to do is to have you MACbook detect the Time capsuple. Open AirPort Utility, select Time Capsule, and click Continue. Enter the password of the time capsule if incase you secured the router.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
May 31, 2011 | Computers & Internet
I used to have a linksys router but now have a Apple Time Machine. When I power up my WGA54G all i get is the power light. When I connect my WGA54G to the Time Machine, only the ethernet and power are lit....
Well, I'm not quite sure what your asking, exactly, but I'll try,
What are you wanting to connect the 'WGA to?
--"I used to have a linksys router but now have a Apple Time Machine."--
The Apple "Time Machine" is the backup "software" that controls the "Time CAPSULE'S" Hard Drive so I'll take it you mean the Time Capsule. The Time Capsule is already wireless.
The Time Capsule is just a wireless router with a Hard Drive in it. You should have set the Time Capsule up the same way you did the Linksys router. The Time Machine software on your computer can now access the Hard Drive for backup purposes.
"Time Capsule" connects to the '"WGA" wirelessly
'"WGA" is connected to a"Game system" (or network ready non-wireless product) via the Ethernet cable.
-"When I connect my WGA54G to the Time Machine,"-
OK,,,,,,, After looking at the manual on-line I think I know what happened, I believe the Manual is wrong! The "NOTE" mentioned to hook it to the Router first but how the heck are you suppose to access it from there? You CAN'T!
I think they had a "Brain Fade" and meant to hook it to the computer.
Hook the 'WGA to the Mac Book Pro and you should be able to access it now. You might want to make sure the MBP's Network connection LOCATION is set to AUTO to make sure it connects OK.
Make sure the switch on the side of the 'WGA is set to - infra- and not -ad-hoc-.
Hook an Ethernet cable to the computer then hook the other end to the 'WGA then plug the power cord into the WGA to turn it on and then try the Ip # it said to use in a web browser. If it then shows the log-in screen then enter them in like the manual said.
According to the manual if you can't access the 'WGA via the IP #192.168.1.250 then it some how got changed and you will have to reset it like the manual say's.
I hope I understood you OK, Good luck....
Jan 07, 2011 | Linksys Wireless-G Game Adapter [ WGA54G ]...
My son has a macbook pro and every time he opens his browser it knocks out the router, a netgear wgt624, and the signal is dropped
Wow, I've heard of Apple Mac's being evil before, but never heard of one knocking out a whole wireless router.
The technology used by Apple Mac and everybody else is really the same. I can't think of a reason for a macbook pro to cause a router to actually stop transmitting signal?
Try a different wireless router ... see if it zaps that one too. If so take the Apple back to the store or to your church for an exorcism.
Newer Apple Mac may have Airport Pro ... with 2.4Ghz and 5Ghz frequency bands in it. It won't have such an amazing amount of power coming out of it that it can zap (like star wars) a wireless router.
By the way Airport Extreme is a very nice wireless router ... and it should play nice both with Apple Mac's and every other kind of computer. And you can link more than one of them wirelessly.
Nov 22, 2009 | NetGear WGT624 Wireless Router
Apr 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
Samsung CLP-300N Laser Printer Logo
80 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
