Question about LG DLE5977 Electric Dryer
Drying manually How can I choose the length of time for drying instead of using the sensor?
  • 1,543 Answers
Select speed dry. The time button changes time (20,30,40,50,60 minutes) and you can use the small silver buttons on either side of the display to add or subtract individual minutes, so you could set for 43 minutes or 67 minutes for example. Remember to select the temp you desire also.
Posted on Oct 15, 2008
LG front load dryer jumps from 40 min to 19 min to 5 min in short time. Any suggestions?
Dryers can base their drying time two different ways. If you are using the "dryness" settings, when you first start the cycle, the timer will show a specific time. If the contents dry fairly fast, the moisture sensors in the dryer will reduce the remaining drying time. This may be what is causing your changes. If you want a specific time on the dryer, or the dryness settings aren't getting the clothes as dry as you'd like, opt for a "timed" dryer setting, where you choose the drying time. This bypasses the sensors.
Aug 02, 2016 | LG Washing Machines
The clothes simply won't dry. I know it is producing heat because the clothes are warm and the heating element is hot to the touch, but the air that is coming out the back is not hot at all. I have...
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Hold down on the 'More Time' and 'Less Time' buttons and press the 'Power' button. if it comes up with tE1 or tE2 you have a thermistor error.
LG DRYER MANUAL
Jan 19, 2011 | Dryers
Hello my dryer doesnt work properly it runs
Problem:
Solution:
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
Jun 17, 2010 | LG DLG7188 Gas Dryer
Not enough heat
You may need to adjust the air flow on your dryer vent.
Problem:
Solution:
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Dle2532 lg dryer, cooling light is always on
I'll take a stab that you use dryer softener sheets. These will deposit a coating on the two metal sensor bars (about 4 inches long, very near the lint filter inside the drum) which prevents the sensor from "seeing" that the clothes are still wet, so the dryer jumps to the cool down portion of the cycle. Clean the metal bars off and it should work again. (note: the bars are not in the cycle if you choose time dry instead of using the automatic cycles)
Apr 11, 2009 | LG DLE2532W Electric Dryer
More dry/less dry setting on atlantis dryer
The more dry less dry settings are basically how much heat you want to use. This is the sensor drying. There is a moister sensor in the dryer that senses the moister on the clothing. When it senses no more moister it will shut off and tell you your clothes are done. The trick with this is that you want to make sure you don't mix your heavy clothing with your light stuff. A t-shirt will dry much faster then jeans and it will sense that the shirt is dry and shut off. I put mine on about the second or third line on the more dry setting and my clothes come out fine. If you are mixing your clothing just put it around the third line. It all really depends on what is being dried. If it's heavy set it for more, if it's socks and such set it lower. Let me know if you have any other questions and let me know if this was helpful for you. Good luck.
Jan 22, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer Changinf time on cycke
Is this on timed or auto dry? Try this with the door open, find the moisture sensor and with wet fingers using the dry finger on other hand to hold the door switch start the dryer and using wet fingers place on both sensors, if it doesnt change to damp or wet it could be the sensor or the user interface.
Aug 10, 2008 | LG DLE2514 Electric Dryer
Display
Check your manual. Sound like wrinkle guard setting
Nov 17, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Error code on dryer display
Check your breakers. Mine was doing the same thing, all of the 120v parts of the machine were working. (blower/drum motor/ lights) However the element wasn't coming on. Went to the breaker and found that one side of the 2 pole breaker was tripped. Turned both off and back on. Heater started working again.
When you set the dryer on settings such as normal or permanent press, it engages the various sensors that help the dryer to make the most efficient use of energy. Moisture sensor, heat sensor etc. (THAT IS WHAT TURNS ON YOUR AD SETTING) Normally it selects a time based on factory settings that it believes your load should be dried by. Say 50 minutes at Normal (high heat, normal) Every so often during the cycle, the machine will check the humidity sensor and the other sensors and try to see if the dryer is still on schedule. Sometimes it will determine that more time is needed, occasionally less time. While it calculates, it displays the Ad meaning that the machine is on auto dry. TO TURN OFF AUTO DRY, set it to a time setting instead of a DESCRIPTION setting.
Oct 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
LG DLE5977 Electric Dryer Logo
81 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
