Question about Bushnell 675x5 EQ Reflector Telescope
The toothed barrel guide
The plastic barrel (jagged) guide broke in two. Can't position barrel forward or backward. Is that repairable or am I looking for new telescope? If the latter is the case, is there any place near Windsor Onrtario that accepts the old one...even for recycling?
Harry Annan
La salle Ontario, Canada
hannan@cogeco.ca
    Problem Solver:
  • 17 Answers
Hannan, you are better off getting a new scope.they are so cheap these days.
try here FREE shipping
http://www.canadiantelescopes.com/Shop-By-Type/Beginner-Telescopes
hope this helps
Posted on Jun 28, 2011
Bernina 440
The jagged teeth on sewing plate are not moving to move the material forward. U will have to look under the machine to check out the mechanism that is supposed to move them and find the part that is the cause of no transmission of power to the teeth assembly.
Feb 15, 2016 | Bernina Sewing Machines
My Shredder W11C stopped working suddenly both forward and backwar. The power source is O K.
if you can hear the motor working but the paper won't pull in and shred then you broke a tooth on the plastic gear. This happens when you try to shred too much at one time. It happened to me but I couldn't find a plastic gear or the company to replace the gear. I liked the machine so I made my own tooth with DEVCON home plastic welder. With a little ingenuity and some tools you could try to fix it. Or like someone said buy a new shredder
May 07, 2014 | Fellowes Office Equipment & Supplies
Power seat not working cadillac
Check that the seat belt mount (often solid plastic or metal that holds the button side of the belt in place next to the center console) is not pinching and preventing the seat from moving forward and back. This happens on many Fords, so it might happen on some GM's too.
If you can hold the buckle mount out of the way while someone else moves the seat backward (or forward), it usually starts working OK again until someone moves the seat to the max forward or max backward position and it gets stuck again
May 02, 2013 | 1999 Cadillac Eldorado
Ignition tumbler pin sheared off inside, don't know how to get it out. - 1998 ford windstar
Hi AJ, You'll need to remove the ignition barrel and take it to a lock smith. To remove the barrel look underneath the plastic cowling around the steering column and you will see holes recessed into it. Remove the screws with a star (Phillips screw driver) and then remove the cowling.. Unplug the ignition switch at the connection (follow the cables downward to the multi connector) and then look at the saddle clamp which holds the unit in position. The bolts are "blind bolts' which will need to be removed. I suggest using a cold chisel or cutting slots for a flat screw driver to fit. Once removed the barrel can be removed. Regards John
Jun 24, 2012 | 1998 Ford Windstar
Key is stuck in ignition barrel ,vt commodore
vt have a nasty problem of snapping inside the back of the ignition,there is a black plastic back on the ignition this is broken try and pry this off then it should release the key ,but dont turn the key forward ,this will wreck the ignition turn it backwards
Apr 09, 2012 | Cars & Trucks
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
Brother sewing machine model 732 (pretty old machine) compal star My machine was sewing forward up to today. I broke a needle changed that since when it wants to go backwards...any ideas what to do I have...
have you checked the reverse lever to see what position it's in?
if the needle broke at the tip end check in the bobbin area for needle fragments
it is possible that a broken needle can jam up or even get the machine out of time.
it may need to be serviced
Aug 03, 2011 | Brother Sewing Machines
Does not sense when the thread is broken during embroidery. Also does not sense if needle is broken causing damage to item being embroidered. This also does not alow for me to back space to position where...
I have an Artisa 180. WHen the threads break I stop it and backup the stitches to where it broke. Read up on your machine and see if it can do this. Look for the icon on the embroidery machine that looks like an S with a tail! It allows you to move forward or backward in the design and find your place where the thread broke. It can salvage a design so you don't have to start over.
Jan 14, 2011 | Bernina Artista 170
LG wm -1832c front loader making noise
when you take the panels off you will see that the barrel is suspended by springs on top and fake struts on the bottom. be careful when removing the panels. if the barrel is leaning forward it's the front struts, if it's tilting upward it's the rear. and be careful how much you load in a front loader
Feb 17, 2009 | LG WM-1832C Front Load Washer
Print jam on the thermal TEC B-572 TXP -3.5
The purpose of the knob if to change the position of the sensor. If you look at the sensor when turning the knob you'll find out that it moves forward (towards you) or backwards (away from you) This should allow you to place the sensor at the correct position. Further more, there are two holes on the plastic flag. the hole nearer to you is the transmissive sensor and the other is for reflective. Try to place the sensor at the correct position.
Mar 25, 2008 | Toshiba TEC B-572 Printer
Bushnell 675x5 EQ Reflector Telescope Logo
67 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
