Question about Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat
Baxi combi boiler 80e safty thermostat light on
Hot water is ok but the c/h wont come on
  • Anonymous Mar 26, 2014
    have replaced hw micro switch and hw temp. sensor
The pump default light is on and it won't heat the floor or the tap water but you can hear the pump running. I checked the incoming filter or screen and on the right hand side of the pump there is a yellow handled valve for a little drain. While the pump is running I opened the valve and nothing comes out. Is the pump shot or what can I try next.
Posted on Jan 25, 2009
Diaphragm is punctured in 3 way valve. replace small one on top of valve. about 7 pounds from plumbing supply centre. Diaphragm on DHW side ok if water still running hot. I would however replace both, as if one has filed the other maybe about due for a change also.
regards
j.
Posted on Jan 10, 2009
The diaphragm has a hole in it. This is the small one on top of the 3 way valve. If you have Hot water the larger diaphragm at the front of the valve will be ok. The diaphragms are in the cases behind the micro switches (On the Brass unit on LH side is you look into the boiler) . You need to close taps under boiler and drain primary circuit, and the when pressure gauge at zero you can remove the thin metal sensing pipes that are located into the 3 way valve. The parts will cost approx 8 pounds each from somewhere like PTS (check Google - Plumbing trade Supplies) Regards
Jay Williams
Posted on Jan 08, 2009
Baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Posted on Nov 02, 2008
Baxi boiler 80E low pressure on boiler how to fix it?
Silver flex hose may be the (correct) filling loop. There may be a valve at each end of it, maybe just one at one end.
Open the single valve slowly and LISTEN for the sound of water entering the system, and LOOK for signs of the pressure gauge rising.
On the dual valve version open the first, then open the second slowly as above. Close both valves when pressure is adequate. Adequate is determined by the specifics of your system, but note that more pressure DOES NOT mean better showers, etc.
It should only take a few seconds to top-up, any longer indicates a significant loss of fluid from the system.
Jan 28, 2013 | Water Heaters
How do i fix problem E119 on a baxi duotec combi 24HE - boiler won't light because of lack of pressure but I have no manual to assist me as the instructions on the boiler says.
http://www.bhl.co.uk/uploads/article1477/Baxi%20Duotec%20HE%20Combi%20Boilers%2024,28,33,40%20Installation%20Instructions.pdf top the pressure by the filling loop
Jan 23, 2011 | Water Heaters
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Oct 12, 2009 | Water Heaters
Boiler coming on,on its own
Sounds likely. But check the timer selector switching [on/off/24hrs] & if you have a room thermostat wired in
Jun 13, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
I need a protherm 80e manual, any idea where I can download one from? The baxi site does not do support manual downloads. :(
This is the manual for 80E. It isn't a manual for the 80e, it's a manual for the 80E, dunno if they are the same or not.
http://www.protherm.cz/upload/1117176168.pdf
If that's is not it, you can browse here =>
http://www.protherm.cz/component.php?cocode=download&dcid=4
Dec 30, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Boiler shuts down repeatidly
i think you will find that instead of modulating as demand requires the boiler is overheating and then re operating after the safety thermostat has operated.
i wilud put some de scaler into the main heat exchanger circuit or add it to the radiators and let it circulate for a while.
also make sure the pump is operating properly to ensure proper water flow.
Nov 17, 2008 | Water Heaters
Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat Logo
673 people viewed this question
Top Protech Systems Water Heaters Experts
Paul Carew
Donni Steen
Are you a Protech Systems Water Heater Expert? Answer questions, earn points and help others
