Question about Oreck XL2200 Bagged Upright Vacuum
Vacuum bag busted
I had a vacuum bag bust inside an oreck can I take the bag holder off and run through washing machine?
  • kez11 Feb 15, 2009
    the fabric bag of my oreck xl has come of at the base,how can i put it back on? thanks xx
  • 438 Answers
Greetings from GoVacuum.com,
Yes, you certainly can take off the outer bag of your Oreck and wash it in the washing machine. You DO NOT however want to put the bag through the dryer!!!!! Just hang the bag outside, and let it air dry. It is important to make sure that the bag is 100% completely dry before you use the machine again. If the bag is wet, it will cause dirt to turn to mud in the bag, and probably cause a foul odor when you use the bag.
There are 2 different types of bag systems with Oreck vacuums. The one pictured below is the older style that uses a metal clamp to hold the bag in place. The newer docking system, will be a white plastic clamp that holds the outer bag in place. They both will be removed the same way however. Simply take a screwdriver and pry off the clamp;
Once you have removed this clamp, simply pull the outer bag off. Once it has been washed, and the bag is 100% completely dry, put the outer bag back over the bag housing as far as it will go. When you put the clamp back on, it is imperative that the clamp go behind the plastic ridges, to ensure that it is tightly fastened. If the clamp is not put on correctly, this will cause the inner paper bag to fall off during vacuuming. Make sure that the clamp is in the right position when putting the bag back;
If you have any further questions, please feel free to email them to me. I really enjoy sharing my knowledge an passion about vacuum cleaner, and vacuum repairs. We do stock all Oreck parts, so if you need any parts, please let me know.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Posted on Oct 15, 2008
Yes you can, take it apart and wash it.
just be carefull drying it.
Plastic blue holder inside bag came off,, how do you reattached so I can but the filter bag on
In addition I would add, that the bag must be fully installed on the upper handle mount before attempting to reinstall the clip. I find that the clip should be installed, then squeezed to install the bag holder, being aware of the proper orientation of this part.
Jun 26, 2015 | Oreck XL Ultra Bagged Upright Vacuum
Blue plastic bag holder on oreck upright detached - how to put it back in?
Amy, not sure from your description whether the outer part is what came off or the smaller, inner part came off. If it is the outer part, all you need to do is squeeze the two prongs of the inner part of the bag holder together and slip the two pegs into the holes on the outer part of the holder. If the inner part came off then you have to spread it, so that it will go over the opening on the handle, and then follow the directions I gave to install the outer part. Hope this helps.
Feb 17, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck xl vacuum smells
You can wash the outer cloth bag by soaking it overnight in water with a mild soap solution and then rinse well and hang it up to air dry. Make sure that it is dry before you run it again.
Feb 16, 2014 | Oreck XL Ultra Bagged Upright Vacuum
The bag won't stay on in the bag container
I thought my Oreck upright vacuum was broken because the bag wouldn't stay on. Even worse, when the bag popped off, I couldn't figure out how to get it back on. There was no satisfy 'click' or any other indication that the bag was installed properly. A good percentage of the time, it wasn't actually installed properly, and the dirt just collected in the space between the bag and the bag holder. (The easiest way to recover from this messy situation was to vacuum out the Oreck with another vacuum! When I do this, I can't help but think how embarrassed the Oreck must feel to be humilated in this manner . . .)
Anyway, after a trip to the Oreck dealer to purchase a replacement part for what I thought must surely be a broken bag-holder assembly, I now know that it's the design itself that is defective. After all the money we paid for the Oreck, my wife won't let me get rid of it. So I just use the cannister vac we got for free with the upright and spot vacuum instead. (I'm seriously thinking about breaking something inside the Oreck so my wife will let me throw it out and get a new vaccuum. We bought a new vacuum recently to use at our vacation cabin for a fraction of the price and it's a joy to use compared to the Orec - it was a Consumer Rerports "Best Buy".)
Feb 06, 2011 | Oreck XL2200 Bagged Upright Vacuum
I would really like to wash the outer bag of my vacuum, but I have a problem. I can remove the outer bag from the vacuum, but the plastic 'frame' that is inside the outer bag is sewn to the bag. So what...
you can wash the bag. However you cannot wash the bag in the wash machine. What you will want to do is look for the screw or depending on the model, untwist the cap down on the rod next to the machine. that entire pole section will come off of the unit below with the bag there.
I recommend if it is warm outside to use the garden hose to spray it and scrub inside the bag with a scrub brush and some dish soap.
I usually throw them into the laundry sink and let soak, scrubbing with soap and water.
To dry the bag, a hairdryer or hang to dry before putting the piece back onto the machine.
Good luck.
Mark
Nov 12, 2010 | Oreck XL2000 Bagged Upright Vacuum
The bags keep falling off
The nozzle pictured upon which the bag holder mechanism broke on my machine. Took it to Oreck dealership twice and he kept replacing the bag holder, but mostly trying to sell me a new vac.
Problem was, the bag holder mechanism itself was no longer attaching to the exhaust port because a major portion of the attachment device simply went missing. Notice that in the pics I post there is obviously something missing. A product failure. We don't abuse our stuff.
Solution? I drilled two small holes on either side of the bag holder mechanism and then fed a very small zip tip around the mechanism and around the plastic cloth bag holder support so it can no longer disconnect. Key to this is to feed the zip tie from behind the plastic cloth bag holder support so that the fat part of the zip tie does not interfere with the connection of the bag support to the bag holder.
Here's a pic of what I did.
Feb 15, 2010 | Oreck XL Ultra Bagged Upright Vacuum
I have an oreck upright cleeaner I have not used for a while where I put bag on is the attachment 2 part because bag will not stay on.
you should have a velcro bag holder slide the bag opening onto the velcro bag housing after it is folded down then with the bag in place swivle the bag housing to the velcro and it should snug up to the inlet tube where all of the debris is vacuumed into , let me know if this helps?? thanks The Vacuum Doctor Don Alb,NM
Nov 19, 2009 | Oreck XL Ultra Bagged Upright Vacuum
The bag blows off my Oreck as soon as I turn it on
Follow the directions. With Oreck OEM bags they should attach easily. You need press the cardboard frame over the small nodules on the bag holder and they will stay in place
Jan 26, 2009 | Vacuums
Oreck 4080 the bag fell off the vacuum,
If the bag doesnt have a bag holder then the bags just push onto the black connector - there is usually a hook at the top of the oval connector where the bag once pushed on, sits over the oval dust channel feeder and locks into place. Once the Oreck is switched on, the bag in theory should stick to the oval hole.
Jan 16, 2009 | Oreck Vacuums
Oreck vaccum
The belt must not be running true to the pulley. You may need a brush roll, but also check the motor to make sure it isn't moving inward after the belt is put on.
May 17, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL2200 Bagged Upright Vacuum Logo
1,731 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
