Question about Hasbro Fur Real Friends Smores Pony
The ponies mouth
My granddaughter pulled the ponies mouth down to far and it will not close or move is there anyway to fix it?
  • memphisdee Nov 27, 2008
    Mine just doesn't work after petting for several minutes????
  • 3 Answers
Hi, the pony's jaw is dislocated. There is a **** in the upper part of the mouth that you can look into to see where the jaw fits back in and can be popped back in place. There are also wire connections that may have come undone that can be reconnected easily.
Posted on Dec 30, 2008
My garage door is a chamberlain lift master. We had to pull the latch and manually close it last week. When I opened it, my super-strength:) threw it open too fast and I think I threw off the main drive...
No need to - the unit has adjustments to control where the door stops on closing. You need to back off a tad on the closing setting so that the door stays closed.
Jul 04, 2017 | Chamberlain Powerdrive PD422D 1/2 HP...
I can't push my toro pony lawn tractor out of my shed is there a release lever for the ****** if not how can i make it possible to push
on the rear of the mower near the tow hook there is a rod with a loop on it pull it out and move it to the side or down to lock it
Apr 17, 2012 | Garden
The governor is stuck wide open. How do you fix it?? Troybilt tiller reardrive 3 horsepower
have you gotten something stuck in the throat of the carb where the throttle butterfly opens and closes to control speed? check this,then check all moving parts on the carb and especially the governor spring that its not caught on something
Mar 31, 2010 | Troy-Bilt Pony Garden Tiller
Troybilt pony wont go into drive.
Not technically a solution, but there are Troybuilt tiller forums out there on the net. MTD bought them out some years back and some parts are still available. I had to go thru them to find a part number for a mid 80's Horse unit that had a broken drive coupling. Anyways, they have parts breakdowns and manuals on their site. And I've seen some on ebay if you need parts.
Jun 01, 2009 | Troy-Bilt Pony Garden Tiller
Granddughter stood on dishwasher door and now it goes down too far when opening. Spring assembly (pulley type) is FINE...but door goes so far down bottom shelf nearly breaks dishes when pulling out
This happens when people leave the door down, I've seen it many, many times, sometimes the door/hinge assembly can be replaced or even bent back, sometimes it totals out the unit...Good luck !
RMK...
Retired GE Factory Service
May 21, 2009 | Dishwashers
Trunk will not close at all
check the pull down motor toensure it has not been broken, i have heard of this before and the problem was when it got slammed it broke the motor. as far as not latching release the trunk and see if it will operate normal. if not lightly press it downand see if it will latch than, the semi-cirle catch must be open and will look like a small mouth when it is opened up.
Jan 17, 2009 | 1996 Lincoln Town Car
Furreal Pony neighs like a broken record
I had the exact same problem, and all I did was replace the batteries. It worked right again! I just knew the kids had broken the neck of it. It sort of slings to the left and neighs over and over again. BATTERY ISSUE :) The instruction manual should tell the consumer this. Hope this helps!
Dec 29, 2008 | Hasbro Fur Real Friends Smores Pony
Putting the halter back together
Finally I found the instructions for assembly of the halter.....here is the link
http://www.hasbro.com/common/instruct/Furreal_Friends_Butterscotch_Reattach_Halter.pdf
Dec 27, 2008 | Hasbro Fur Real Friends Smores Pony
Horses mouth
I had the same problem with mine. There is **** in the upper part of the horses mouth if you gently pull it open a bit and look inside to the jaw area you can see where to reconnect the jaw and pop it back in place. There is also a wire connection near the mouth, so check and make sure this is also connected.
Dec 02, 2008 | Hasbro Fur Real Friends Smores Pony
Hasbro Fur Real Friends Smores Pony Logo
495 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
