Question about Sharp Aquos LC-30HV4U 30 in. LCD HDTV
No voice I have no sound. The tv is not muted. I am very upset because I DO NOT KN0W WHAT TO DO NEXT? HELP PLEASE
First u have to chek pri amplifier stage 4 exp
at the back of it theres a pin av out put insert a pin (av pin )in audio out put n the second end in (take any amplifierto which there' audio in put 4 eg a music system)the music system play n c it aux on ur music system if there's audio there's audio then pri amplifier is ok there' prob with ampli card replace it
if not contact on my no 9764434445i will b happy to help
Posted on Nov 11, 2008
Sceptre tv: no sound but i have picture
Please check whether sound is coming to headphone. If yes, there is some lose contact in the board. If no, try another input device that you are sure works well. If problem persists, please refer it to a qualified service technician.
Jul 29, 2012 | Sceptre 32 X320BVHD 32 LCD TV
We have a DVR hooked up to our 1989-99 Mitsubishi TV (floor model) still in amazing working condition. The remote control for that TV never allowed us to put the TV on mute. If the mute botton was...
Well, without knowing the exact model of tv and remote, I can just give my best guess.
Try using the volume up/down on the TV and / or the remote.
On the TV, try pressing both the volume up and down at the same time.
Stick the remote right in the face of the TV (direct in front of the remote sensor) and hit the mute button.
Try tapping the mute button in very short single bursts rather than pressing it for a half second like you would any other button.
If any of those work, please come back and reply with the model of the TV and remote, because someone somewhere probably has the same issue and would love to have it solved!
Feb 24, 2011 | Mitsubishi Televison & Video
LG LCD TV/DVD - I have full picture and sound with
is a mute function enable or a defective control board. Needs to be checked. send to repair store.
Jan 16, 2010 | LG 42LB1DRA 42 in. LCD Television
Some of my comcast digital channels are muted, while others are not.
It sounds as if you have accidentally turned on your secondary audio settings.
Here is how to fix it....
On your original TV remote next to the "0" key there is a button marked "sound". Press this button until the TV says stereo.
This should fix your problem.
Good Luck and please rate this solution...
Jan 08, 2010 | Haier HTF20R21 20" TV
No sound from the tv tuner card
1. Did the sound ever work?
2. If so, then the short cable that is connected from the TV card to your computer sound card came loose.
3. If it has never worked, then you need an audio cable to connect the TV Audio OUT to your Sound card audio IN.
4. If it has worked and the cables are ok, then the "Audio IN" mute box is checked. Double-click the "speaker" icon on the lower-right of your desktop. UNcheck any of the audio mute boxes.
It should work now. If you need clarification, please reply.
Hope this helps!
Sep 03, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
You have just performed the best way to troubleshoot this kind of problem. Check all cables on the back of the tv and your sources and look for any loose or disconnected cables. Next, Hook your DVD palyer to the SAME input that you are using for the cable box. Now if you have good pix and sound then you have a bad cable box. If not then you have a bad Main bd in the tv.
Jun 30, 2009 | Samsung LN37A530 37 in. LCD HDTV
No sound, volume knob is blinking
On the bottom of the remote on right side, right next to the master volume - key . it is actually called muting instead of just mute. Hope this helps.
May 05, 2009 | Yamaha RX-V690 Receiver
Closed Captioning comes on every time i turn on the tv!
Apparently the 2002 Sharp model TV that I purchased has the closed captioning by default if the mute button is engaged. So there is no solution for my particular model, it has been built in this way. The only solution is not to use the mute button and lower the volume instead.
Jan 03, 2009 | Televison & Video
Tv no sound
Ther is a problem with the sound box of th TV. Please contact the company from where u purchased ur TV set. And please from next time onwards send your correct and full name or u will receive no help from me. If any other problem is there then feel free to contact me at
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
this might sound daft but your speakers might have blow or if u are running cable/sky u might have muted it on that
Jan 14, 2008 | RCA F19625 19" TV
Sharp Aquos LC-30HV4U 30 in. LCD HDTV Logo
97 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
