Question about Zanussi Washing Machines
Having freed drum of sock in mechanism the control panel is flashing and needs resetting before I can re-programme for a new wash. Is there a re-set procedure?
  • 750 Answers
Hello bmn1
Welcome
You said, Having freed drum of sock in mechanism the control panel is flashing and needs resetting before I can re-pro gramme for a new wash.
Lets try and reset the system,
1.Unplug the washer and wait 5 minutes, if you can not reach the plug turn off the breaker
for 5 minutes instead.
2.Then restart washer like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech may have to make the electronic diagnoses.
How old is the washer?
You will be fine
Bless You
Please remember to leave a rating
Posted on Oct 15, 2008
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
NEFF W5420XOGB washing machine - 400 RPM, SPIN and READY lights keep flashing with any programme selected. Resets when door is opened by manual pull lever, but reoccurs when new programme is selected. A ny...
The bottom panel under the drum should be removable. Then you can access the manual drain plug. Beware that a lot of water comes out. When you remove the plug, you should see a filter and you need to clean that out. Reassemble the unit and try again.
Dec 02, 2013 | Washing Machines
My zanussi aquacycle 1000. Programme knob is just cycling through the was cycle really quckly without the machine washing, the drum is moving slightly back and forth and sounds like its trying to engage...
Could be that the drive pulley behind the drum has loosened on the shaft. You do not say that you can hear the motor, but the drum moves slightly. Some machines have a shear pin which fails to prevent damage to the drum and motor. If you machine has one of these, it will be obvious when you get the back off. The lack of load on the motor could do strange things to the programmer. Good luck.
Jan 31, 2018 | Zanussi F1045W Front Load Washer
I select a programme and then press the start button, the door locks but the start light flashes, and nothing happens
When the program is pressed to start then the inlet valve must open and allow the water to come to the drum. if this is not happening then check the voltage to the inlet valve, if there is no voltage then the program controller is not outputting and so defective.
If not the inlet filter/valve is clogged and will need a back flush .
Apr 11, 2011 | Washing Machines
How to cancel drying?
Please press the reset switch which should be on the control panel or next to the loading door
Nov 14, 2009 | Indesit WA 115 Front Load Washer
Kenmore HE 2 Front Load Washer Leaking
Remove the top, by removing the 3 screws in the rear. The top will slide off toward the back. Next remove the control panel. Remove the 2 screws on each end on top. Remove the detergent drawer. Remove the torx screws behind the detergent drawer. The control panel will now snap off, pulling from the top and lifting up. Once freed, remove the control panel ribbon cable from the side of the main board. Now remove the screws holding the door switch mechanism in place. Remove the spring that holds the outer part of the boot from the front panel. Now remove the 4 quarter inch screws that hold the front panel and door on the front. Now you can install the new boot with ease. Just reverse the process when the boot is on the tub. Make sure to have the mark on the boot ^ lined up with the mark on the tub on top.
Feb 20, 2009 | Kenmore Elite 45986 Front Load Washer
Beother Hl 2040 printer
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 28, 2008 | Brother HL-2040 Laser Printer
Yellow Toner Light Flashes - won't print
Aug 22, 2008 | Brother HL-2040 Laser Printer
INDESIT WD10 WASHER N DRYER WATER WONT EMPTY PLZ HELP
I had exactly the same problem, found the answer on another website. The filter had a small sock stuck in it, stoppin the ppump from turning and draining the water out. Lever off the front panel right at the bottom of the washine machine, then unscrew the round black plug, lots of water will come out. Pull out the black thing and stick you fingers inside and pull out watever is blocking the pump. Turn off the electrics first. Mine now works fine again. :)
Mar 21, 2008 | Washing Machines
Washing machine fill but won't go through cycle.
Too empty your machine reset the programmer to Final spin. the machine should empty normally.
If you have a fast flashing light its most likely to be 1 of 2 things.
1. The belt from the motor has broken. (price for belt is less than 20 pounds.)
2. The brushes in the motor have worn down too much to make the drum turn. Look underneath the washing machine to see if black power (Carbon) is deposited under the motor.
(Price for set of brushes is less than 20 pounds)
Labour should be no more than half an hour by anyone decent.
Regards
Feb 22, 2008 | Hotpoint WMA46 Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
