Question about Sharp AR-M208N Copier
Shart AR-M208N Toner Replenishing
My printer has been saying the toner is replenishing for the last hour and half now- how do i get this to stop
    Scholar:
  • 92 Answers
Have you removed the seal from the toner before installing it in the machine? If so, make sure it's all removed. If that looks ok there may be a problem with your machine.
The 208 is a fairly new machine, you might still have warranty on it. I'd check with Sharp or with the company you bought it from for repair info.
Posted on Oct 16, 2008
Sharp AR5516 Printer Error F2 40 Pls Provide Solution
Detail:
ATC sensor value abnormality
Cause:
Connector connection trouble
Toner cartridge installation trouble
Sensor breakdown
Check and remedy:
Connect the connector again.
Install the developing unit again.
Replace the developing unit with a normal one.
Thats what the Manual says, your toner is not replenishing , could be your toner motor , or your toner is empty , or your developer sensor
Feb 24, 2015 | Sharp Office Equipment & Supplies
Please set replenish toner unit correcty
Replenish toner unit is the unit that is secured with two screws and comes to the right and these are unscrewed. The presence of this unit is signaled by a sensor positioned under the top cover. Check that sensor for proper functionality in Service Mode.
Jun 01, 2014 | Konica Minolta Bizhub Press C6000 Copier
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
"TONER REPLENISHMENT IN PROGRESS
please remove the waste toner stored in the waste toner content box
Jan 11, 2011 | Sharp AR-275 Copier
Will you please help me what to do, it says "open the toner intersetion port cover, unlock the black toner and pull it out" but it fact I dont know anything baout machine, so how can it be repaired. Thanks
you need to open front cover, on left side you will see blue cover wich you ned to open to get to the toner, automatically the copier turns the enpty toner to "pull out" position, in your case its black tube, wich you need rotate clock wise and pull out.
Then insert new tube, hold it and pull out the ribbon, all the way out and rotate tube anticlockvise.
Close all covers and machine starts toner replenishing.
Hope that helps!
Aug 19, 2010 | Canon iRC3100 Printer
Keeps saying to add toner
replace toner. if persist use simulation 132 to replenish toner
Aug 03, 2010 | Copystar CS-2030 Copier
ML-2510 Laser Printer : persistent blinking red light
Dear
This problem you will be noticed when toner is 90% empty.
Does the printer is functioning or No. If yes the problem is 90% toner is finished.[10% toner remaining alert]
If printer is not functioning Please change the toner from Genuine dealer. Else your printer fails due to non genuine and refilled toner.
Nov 11, 2009 | Office Equipment & Supplies
C2557 error message
If is a BW 350 go to service mode ( stop 0 0 stop 01) counter apecial part counter reset drum and dev switc off the very quiqly service mode function run f8. Did you replaced drum and developer?
Aug 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Sharp AR-M208N Copier Logo
167 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
