Question about HP LaserJet 1100 Printer
Print smear My co-worker has an HP LaserJet 1100. When printing a document, the letters on the page are smeared - like someone colored in all the zeros, but it is all the letters. The document is still readable, but not professional looking. We did try installing a brand new HP ink cartridge, and got the same result. Any ideas? Thanks for your help.
  • 47 Answers
It might be the fuser that is defect. perform a half paper path test. Let the paper get pulled in for half of it's length and open the cartridge door so printer stops, check the paper and see if issue is on the out print before passing the fuser. Also check that you have the power cord directly to wall socket and not using an extension cable that may reduce the current to the printer. Another tip can be to change paper type in the printing preferences to a heavier type ex. card stock wich have the printer to work slower.
Posted on Oct 16, 2008
Smearing on the right side of the page
See the user guide on page 191 and following to clean the paper path.
Nov 16, 2011 | HP Laserjet CM2320nf All-In-One Color...
Hi I am having a problem with our business HP LaserKet 424n printer; when we print anything out it seems to make a noise that it normally doesnt make, and our paper ends up looking smeared to the point ink...
Take print out of configuration page(menu-information-configuration page), chech the maintenance kit interval 2,25,000 crossed?
YES... replace maintenance kit & Swing plate assm..
NO... check fuser sleeve surface arrested with toner?...Replace fuser...
Sep 04, 2011 | HP LaserJet 4240n Printer
Yellow smear on left side margin from top to bottom of the page. After cleaning, the smear reduced to one third and confined to the lower left corner. How do I get rid of it entirely?
What did you clean? If it was the Image Transfer Belt (the big mylar belt in the front), do it again. Print and see if the yellow is smearing again. If it is replace the yellow cartridge.
Jan 31, 2011 | HP Color Laserjet 3550 Printer
HP laserjet 5000gn when i print, output smears ink on 2 sides. not a toner issue cause changed toners already. someone says printer is telling me something and might be a warning of
If by smearing you mean the print is also rubbing off? Then you definately have a fuser unit issue. The fusing unit is the assembly that heats up and "fuses" the toner onto the page. When these start to go bad, usually on one edge or the other the print will smear/double image/wipe off of the effected area. One test you can do to verify a fuser problem is to print a page and then when the page is about half way thru the prcess, shut the printer off. Open the top and remove the toner cartridge, pull out the page and see if the lower part is not smeared. Basically what your checking is to see if the print is ok BEFORE it goes thru the fuser. Based on your description I would suspect your fuser is going bad.
Good Luck and Thank You for using Fixya.
Sep 09, 2010 | HP LaserJet 5000gn Printer
Yellow not installed
Are you using a factory new HP cartridge? If so, contact HP and request a warranty replacement of the toner cartridge.
Jul 13, 2009 | HP Color LaserJet 2600n Printer
When printing the printer is leaving smears on the left side of the page and random letters. If I make 20 copies, the first 5 and the last few will have the marks. I already changed the drum and all...
you need check
1) you may make sure the smear occur after the photo drum unit or after fuser unit, you can stop printing when the paper goes around between the drum unit and fuser unit,
2) clean or change fuser leaner if the random smear occur after the fuser unit(not after the drum unit).
3) still check new drum unit there is a cleaner on it, it could be the smear occured if not enough cleaned drum surface
hope you fix it
May 06, 2009 | HP LaserJet 2840 Printer
All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
HP Printer problem
Sounds as though one of the drum cleaning blades is failing.
When you see the double image shadow, is it any particular color? If so, that's the drum unit that is failing.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 1100 Printer Logo
172 people viewed this question
Seeker5211
Seeker5211
