Question about Whirlpool Dryers
Wish to replace thermister #3976615 on GGW9868KQ2.Is the termister easy to get to?
Depending on the model of your dryer it's very easy. If you have a 27" model that opens from the front panel, it's right there on the exhaust duct near the front.
Posted on Dec 20, 2009
Mazda 1992 proceed red light on dash on not water temp replaced termistate still on 4x4 2.6
Please take your time and explain the whole problem. I can't understand what it is you are trying to say
Sep 04, 2016 | Mazda Cars & Trucks
How to replace a thermister?
A thermister reads temperature by resistance (ohms). Higher the temperature gets the lower the resistance. It is two wires just pull them out and replace. It does not matter if you interchange them. Your unit reads the thermister to determine temperature.
May 28, 2014 | Fujitsu 24R1 Air Conditioner
I have a whirlpool cabrio dryer model WED6600VWD. What does the F1 error code mean?
The F1 error code means that the thermister (cycling thermostat) has a open circuit and should be replaced.
To check the thermister you would need to DISCONNECT POWER TO THE DRYER remove the lower small front panel below the main one where the door is at and using a digital meter set to measure ya would remove the wires from the thermister and check for appx. 5,000- 7,500 ohms at room temperature.
If the ohms at within 5 thousand to 7thousand 5 hundred at room temp. the thermister is good and the control board is what the problem is....if the ohms is way lower or higher that 5-7,500 ohms the thermister is going to be what would need to be replaced.
Here is what the thermister looks like
I hope i have been able to help you fix your dryer,
GENE
Oct 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How to test a dryer thermister
Hi mdecker1
The way to test a thermister is to remove the wires (tape them together for later use) from it and test the leads coming from the thermistor with an Volt/Ohm meter...it should read continuity across the two leads.
But sometimes they will be bad but show good with the volt/ohm meter, so I also recommend the action below.
The easy way to see if the thermistor is bad is to tape the two wires ends together (see above) and turn the machine on...it it comes on and heats...replace the thermistor.
Please take time to rate me thumbs up
Sep 15, 2011 | Kenmore Dryers
GGW9868KQ2 - Whirlpool Dryer does not stop when door was opened. How to open the top to check what was wrong?
Its probably your door switch. As for taking your dryer apart well it's one of those, I can show you better than I can tell, kinda things. Search "deconstructing a dryer" and "appliance assistant" for the video.O7OUT
Sep 07, 2011 | Whirlpool GGW9868K Gas Dryer
My GEW9200LW0 electric dryer will stop after a few minutes and flash E1 code. Is it most likely a faulty thermistor? How do I know the correct part # to order?
HI, the thermistor is the culprit in this situation. the actual location of the affected part is inside the unit, on the blower housing(mounted on the backside). The part number is (3976615)
E-1:=(Failed Thermistor)
SIDE NOTE:-The manufacturer has replaced part number 3976615 with this item, part number 8577274. 8577274 may differ in appearance, but is a functional equivalent to prior parts including 3976615.
Oct 21, 2009 | Whirlpool Dryers
F2 displayed when using self cleaning
REPLACE THE OVEN TERMISTER PROB IT WILL FIX YOUR PROBLEM. CALL 800-614-2700 TO GET PRICE ON IT AND HAVE MODLE # REDAY
Jan 25, 2009 | GE JKP15 Electric Single Oven
Dryer
Derf, E1 means an open thermistor. If this is a front loader, remove the lower panel by removing the 3 screws on the bottom panel. The thermistor will be sitting right behind the blower housing next to a white thermal fuse. The thermistor is the black one. If this is a standard model the lower panel should open by sliding a puddy knife on the two clips and pulling foward. The thermistor is in the same place as a front loader. Your part number should be 3976615. An easy job. Don't forget to kill the power to the unit when repairing...Good luck.
May 15, 2006 | Whirlpool GGX9868J Gas Dryer
Dryers Logo
393 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
