Question about LG WM2277H Front Load Washer
Loud gear noise in spin cycle.
During spin cycle, there is a loud gear or bearing noise. Looked in the back and there is a rusty stain where a watery substance is leaking out the rear bearing.
  • marcelkern Oct 15, 2008
    The washer is approx 4 years old
  • marcelkern Oct 30, 2008
    Thank You MNTECH !!! I took apart the tub assembly and you were correct, the rear seal caused the water to damage the bearings. The outer rear tub assemble and a new spider fixed the problem. It was a big job, but I was able to do the work myself and save a bunch.
    Thanks again,
    Marcel
  • 1,543 Answers
That's bad. That means the rear seal has leaked into the rear bearing. The fix would be to replace the back outer tub assembly 3045ER0008N and probably the spider 4434ER0002A for the WM2277HW. They do list separate seals and bearings, but they are hydraulically pressed into the outer tub, so realistically that is not an option. Figure at least 2 hours labor. It's a big job, and not very cheap. Please don't bother rating this, as anything other than a FixYa would drop my rating, and I don't think you want to shoot the messenger.
Posted on Oct 15, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Oct 30, 2008
    Glad to hear you were able to fix it yourself and save some $$$. I would appreciate it if you would rate my solution as a FixYa. You may have to rate the other guys response as a helpful in order to rate my solution. Thanks.
  • 750 Answers
How old is your washer.
Unfortunately the first techs post is right on target.
Here is an article I just read that may help you make a decision.
Repair or replace
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to advise you.
Please do not forget to leave a rating.!
Thank You, Huuum
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Loud noise when spinning out
it needs new drum bearings and seals, it's a big job here a video that will show you what needs doing
Jan 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Makes very loud noise when in spin cycle
Thanks for choosing FixYa Steve and welcome to the site. Anytime you have loud noises during the spinning cycle, it can almost always be related back to your motor drive. It controls the spinning, agitation also. It is either the drive motor or the spin bearing more then likely. None the less, it will need to be looked at to determine the cause. You will probably find your problem at these two points Steve. They are common.
Apr 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
When in spin cycle machine makes a very loud whining noise
Most common cause for your whining noise is because the seals have failed/worn and allowed water into the bearings..Rusty ball bearings are not smooth...Hence the noise.....Probably needs bearing/seal and probably shaft replacement....Big job..Get quotes....Good luck...Nomess
May 20, 2010 | Washing Machines
Whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
May 15, 2010 | Washing Machines
When entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Oct 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Loud steady noise during rapid spin cycle
sounds like the bearings are on the way out bud they can be changed but its not easy
Aug 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
LG WM2277H Front Load Washer Logo
361 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
