Question about ASUS P5PE-VM Motherboard
Boots up for ~15 sec. then shuts down
Our Asus P5PE-VM mobo is currently being testy with us. It will start up fine for ~15-20 secs, then it shuts itself down. I can watch it load up on the monitor briefly, but then it shuts down. I recently (last month) replaced the PSU, and previously we were having overheating problems. Any suggestions? I need this ****** up and running!
  • 1 more comment
  • pkwyhdwe Oct 15, 2008
    Fans are good, and I just reset the heatsink. I'm rebooting now and we'll see how things go. Thanks for the help *keeping fingers crossed*
    Okay, here's the latest:
    I've gotten further through the boot process, however I get the following errors part way through:
    - Error: /bin/insmod exited abnormally
    - VFS: cannot open root device "label=/" or 00:00
    - Please appen a correct "root=" boot option
    - Kernel panic: VFS: Unable to mount root fs on 00:00
    After that, it'll sit (long enough for me write all of that down) and then eventually shut itself off.
    So....what now?
    any difference if I've got grub rather than lilo? I've gotten to this point:
    grub append> ro root=LABEL=/ hdc=ide-scsi
    I'm guessing that I would change this to ...LABEL=/ dev/hda
    ?Is that correct, or am I way off at this point?
  • 788 Answers
Usually a motherboard will shut the system down to save itself. So check that the fans are spinning and that the heatsink is properly seated. You should also test in a minimum configuration be removing all add in cards, disconnecting all drives and unnecessary cables, and removing all but one memory module. If this doesn't point out the faulty components then either the motherboard (most likely) or CPU (less likely) is faulty.
Posted on Oct 15, 2008
  • Dean Joly
    Dean Joly Oct 15, 2008
    Your Linux boot loader can't find the boot partition. I found this thread that might help you: I'm not a Linux expert. You may try booting from a Linux live CD and try to repair your boot loader. There a lot of information if you Google for "VFS: cannot open root device". From what I've read you should change the label=/ line in lilo.conf to label=/dev/hda.
I have a Asus P5PE-VM. When i turn on PC it gives me following error and shuts down after 15 sec. Cannot even get into Bois. "USB device over current status detected"
Couple of things will cause this:
1] a problem with the front USB connectors - you can try just unplugging them from the motherboard and see if this will help
2] a short circuit caused by the metal raisers that is used to hold the motherboard in place - sometimes - just loosening the screws that holds the motherboard in place will do the trick, but if u have the patience, you can remove the motherboard and look for any place that the metal from the raisers that holds the motherboard in place is touching tracks on the motherboard.
3] I don't think i should have to mention this but of course, if you plugged something into the USB port that is drawing too much current - just remove it.
Feb 07, 2011 | ASUS P5PE-VM Motherboard
USB Over Current Status Detected, Computer will shut down in 15 seconds
this message popped up because one of the device which you connected to the usb of the pc was overdrawing current i.e more than 5V DC. Hence, the built in system security gave this message and will shut down your computer in 15 seconds. In order to avoid this message first remove all the usb items connected to it and then connect one by one and detect the faulty one and replace.
Jan 29, 2011 | ASUS P5PE-VM Motherboard
Can i put video card on p5pe vm? and what video card
It has an onboard video, so you don't need one, but if you want to add a better one it must be an AGP 8X/4X card and must be +1.5 volts.
A manual for your board is:
look at page 1-20 about video cards
Jul 23, 2010 | ASUS P5PE-VM Motherboard
Problem with ASUS P5GD1 mobo
Try taken the bios battery out for about 30 secs, replace it and then reboot, after post press F8 untill you have a screen pop up with a safe mode option use the arrows keys to navigate to safe mode and press enter. In safe mode goto my conputer c:drive(boot drive) windows. In the windows folder look for a file called prefetch, delete all it contents. Exit out of everything and restart the pc. If same thing happens post back.
Feb 05, 2010 | ASUS P5GD1-VM Motherboard
What mobo can replace ASUS P5PE-VM
the socket of you processor is lga775, the graphics port is agp and it support DDR I , so you need to buy a motherboard that has the exact specifications.
my advice is to continue with asus. you could buy an Asus P5P800/ P5S800 that is compatible with your previous motherboard. there are also some good models from asrock and they may be cheaper than asus.
the problem with this type of motherboard is that they are expensive because that are not in use.
Dec 20, 2009 | ASUS P5PE-VM Motherboard
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | ASUS P5PE-VM Motherboard
Asus p5pe-vm
"USB +5v" = VCC
"USB_P5-" = -D
"USB_P5+" = +D
May 15, 2008 | ASUS P5PE-VM Motherboard
P5PE-VM asus board audio driver
Hello there.
Please click here to download the drivers for your audio chipset. You may note that Vista is not listed but the driver version for Windows XP works in Vista, there was a problem with the installer cd on Vista but apparently manually running the installer for the audio card, from the cd works fine. Click here to see what other users of the same motherboard said.
Hope this helps.
Apr 19, 2008 | ASUS P5PE-VM Motherboard
ASUS P5PE-VM Motherboard Logo
193 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
