Question about Ricoh Aficio 1013F Copier
Ricoh Afcia 1013F Need to change Modem Speed for Use with VoIP
I need to change the baud rate to 14.4Kbps and I can't find information anywhere how to do this. Is their a manual, besides the user guide, that tells you how to get in maintenance mode? What settings work best with VoIP?
  • 1 more comment
  • zachwilcox Oct 15, 2008
    Is there any way to change the Baud rate regardless?
    No I don't. Will that slow the baud rate? Can you tell me how this is done?
    Do you know how to adjust the baud rate on aa Ricoh Afcio 1013F as well?
  • Ricoh Master
  • 2,794 Answers
That fax modem isn't compatible with VoIP. You need a seperate analog phone line to get it to work.
The maximum baud rate for faxing on that machine is 9600kbps.
Posted on Oct 15, 2008
  • 1 more comment
  • Tim Babcock
    Tim Babcock Oct 15, 2008
    That copier can only go up to 9600 at the maximum. It is set at the maximum speed by default.
    14.4 is an unusual speed for faxing on.
  • Tim Babcock
    There are two different fax options for that particular series of copiers.
    I think yours is a B465 unit. If that is the unit, it can go up to 33.6. Do you know how to set the bit swithes?
  • Tim Babcock
    33.6 is fast. How it works is you set the modem for that fastest speed possible. It tries to connect to the modem at 33.6. If it can't handshake at that speed it drops down to the next speed. It keeps this up until it can find the fastest speed possible between the two machine. If the other machine can only connect at 9600, it may take a few minutes for it to find the correct handshake because it has to go through 11 attempts to handshake. Sometimes that can time out a modem and it will disconnect it.
    It's complicated to set it up, but this is how service mode works.
    To get into it press the
    1. Ensure that the machine is in standby mode.
    2. Press clearm mode button, then press 107 then hold down
    clear/stop button for more than 3 seconds.
    The SP mode main menu appears.
    3. Press 2 to enter the fax service mode.
    You need to set the G3 switch 05 to:
    Bit 3 = 0
    Bit 2 = 1
    Bit 1 = 1
    Bit 0 = 0
    Do not change bits 4 & 5.
    That will change the initial rate on the fax machine to 14.4
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
How do I turn off ECM in my Brother MFC 8220?
From the Brother website:
If you are using Voice Over Internet Protocol (VoIP), (a technology that allows you to make telephone calls using a broadband Internet connection instead of a regular (or analog) phone line, review the information listed below. If you are not using VoIP continue to Step 8.
Voice Over Internet Protocol (VoIP) is not a marketed feature of your Brother machine, however there is a compatibility setting available with this machine that may assist with sending and receiving faxes when using VoIP. Adjusting this setting lowers the baud rate (modem speed) and turns ECM (Error Correction Mode) Off. To adjust this setting follow the steps listed below:
  1. Press Menu or Menu/Set => Fax => Miscellaneous => Compatibility.
  2. Select Basic.
  3. Press OK or Menu/Set. (For touchscreen models, skip this step.)
  4. Press Stop/Exit.
Jan 07, 2011 | Brother MFC-8220 Fax
Change baud rate on panafax uf880,885
That won't make any difference. ALL fax machines are ANALOG and won't work on a DIGITAL phone lines reliably
Nov 17, 2009 | Office Equipment & Supplies
Fax header Ricoh 1013F
GEEZ, the 1013f, I beleive you have to access the user tools buttom, it is on the left side of the control panel. From there slect fax features, then select general/settins adjust, then program fax information, then slect fax header, from there you will use th alpha keys on the left side that double as the one touch keys. When you are done select ok!
http://copierquestions.websitetoolbox.com/
Aug 13, 2009 | Ricoh Aficio 1013F Copier
I need to change a baud rate to9600 for telephone line. can you direct me please.
How to change the baud rate....
Press Menu/Set, 2, 0, 1.
Press ▲ or ▼ to select Basic or
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
* High is available for FAX-2910, FAX-2920
and MFC-7225 only.
Note
bps. Unless interference is a recurring
problem on your phone line, you may
prefer to use it only when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps..
Jul 29, 2009 | Brother Office Equipment & Supplies
Need to change Baude rate of HP 4215 all-in-one mechine
1. Press the setup button (upper right corner of the fax machine)
2. Keep pressing the setup button until you get to the fourth option which says "Advanced Fax Setup"
3. Press OK to select the "Advanced Fax Setup" menu
4. Then using the left or right scroll arrows (below the OK button) scroll till you get to the sixth option which says "Fax Speed"
5. Press OK to select this menu item
6. Press the right scroll arrow till you get "slow" for the fax speed.
7. Press OK to accept this selection.
Then initiate a fax as you normally would.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Baud rate
1. Why 9600?
Because you are using a VOIP service it can from time to time lose connection briefly. The slower the speed the less data can be loss do to network congestion. It also gives the error correcting function of the receiving fax a better chance of filling in any lost data.
9600 is a good choice becasue the industry minimum is 9600. This means you will be able to communicate pretty much any fax thats is still tickin today. Raising the speed will get you a faster transfer but will also increase the chance that you are sending data at a faster rate than the recieving fax can send.
2. How to change the baud rate....
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
and MFC-7225 only.
Note
14400 bps.
33600 bps.
May 28, 2008 | Brother IntelliFax-2820 Laser Fax
2,015 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
