Question about Compaq Evo N610C Notebook
Unit shuts off as it's powering on.
I have a compaq n610c with 768 mem and windows vista installed. I am finding now that when I am booting up and I see the beginning Vista screen (it doesnt complete), it powers itself off and recycles itself forever until I finally pull the power cord. I've pressed F8 to disable the unit from rebooting when finding an error but it seems to ignore it.
  • msorgen3 Oct 16, 2008
    I can only run it without the battery in. It was an additional problem that I didn't put down originally. I know the fans are running because I feel the heat generated. I also have a lap fan as well to cool it down. I have checked the vents and blew them clean with a duster.
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    hmmm..try this with no battery, just to eliminate a possible cause.
  • 788 Answers
Make sure the fans are running and that their is no dust build up in the vents.
Posted on Oct 15, 2008
  • Dean Joly
    Dean Joly Oct 16, 2008
    If it's already running without battery then either the motherboard is faulty (most likely it's voltage regulators) or there is a chance you have bad RAM. If there is more than 1 RAM module I would try one at a time by itself to see if one of them is good. If both RAM modules cause the same problem then the next obvious culprit is the motherboard. You may find a replacement motherboard online, eBay is your best bet, but it might be pretty pricey.
Wireless internet does not work on my Compaq Evo n610c Notebook PC . where can i find the driver?
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
Aug 22, 2010 | Compaq Evo N610C Notebook
Compaq evo n610c 1gb ram is support for windows 7
Not at all!!
I've installed Windows7 in my n610c (with !gb ram) and my laptop is perfectly working.
Windows 7 is not the 'awful' Vista!!!
The most important things are W7 drivers for this laptop. In order to obtain these drivers, you've to download and install 7zip, then you've to expand in folders the exe files of audio ,video, etc.  drivers of windows xp, and let the system find the suitable drivers..
InstallingXP drivers (exe files) in W7  is not possible!
Also ram may be increased over 1Gb, but you've to install the O.S.
after having upgraded your ram, otherwise graphic card will be not working, even reinstallig its driver!!!
I've just made these operations in two Compaq evo n610c, successfully.
I'd  a problem only for Infrared port, but I've fixed it 'asking' system to find the driver into an external usb HDD full of drivers of various PCs. After a few time , also Infrared port driver was OK.
I've made a backup od windows7 drivers (you may use double driver(free) or Windriver Ghost (not free), in order to backup w7 drivers.
Apr 18, 2010 | Compaq Evo N610C Notebook
Screen turn off of Compaq Evo Notebook N610c
check your settings under power options in control panel, also check advanced power options in bios. very likley you will find problem here.
Jul 25, 2009 | Compaq Evo Notebook N610c
How much more memory can I install
This laptop can support up to a max of 1 GB of RAM , so if you buy 1 stick of 1 GB of RAM you need to take out the 768 MB and just put the 1 stick of 1 GB RAM, or your other option is to buy a 256 MB of RMA so your computer will still have a max of 1 GB of RAM and that would be cheaper and you can still use your old RMA on your laptop , this is the lin for the complete specs of your laptop
Hope that helps...........
Sep 28, 2008 | Compaq Evo N610C Notebook
Battery installer
My compaq evo n610c have the following problem: "103 circuit charge failure" and use power AC only.
best regards
Sep 19, 2008 | Compaq Evo N610C Notebook
Screen goes off
Try booting into safe mode.. press F8 before the windows screen, and select Safe Mode as the boot option. If that is a temporary fix, then reinstall the driver, and make sure your Hertz settings are correct!
Aug 07, 2008 | Compaq Evo N610C Notebook
Ram upgrade
youll find your memory underneath your laptop beneath a compartment door which is secured by usually one screw.remove screw and lift hatch to view mem.either one or two slots will be available.mem looks like oblong board with chips on either side of memory board are clips.push clips outwards and lift out mem board.when clips are removed mem board will lift to about 45 degree put new mem in; place board in housing ,dont worry they only go in one way ,then push down till clips secure
Mar 01, 2008 | Compaq Evo N610C Notebook
Compaq Evo N610C Notebook Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
